Replacing Leds - BMW Forum - BimmerWerkz.com
Old 09-24-2004, 01:49 PM   #1 (permalink)
Car: 2008 128i
I just got my stellar alarm. I don't like where the LED is located (in thingy that goes on the windshiled to tap that will send page to the fob.)...
Anyways I broke my LED (I was playing with it.)
anyone have suggestions for a replacement LED as far as specs go for replacment so that I can put it someplace else like center console or mirror like pres..
2008 128i Jetblack
Old 09-25-2004, 01:37 AM   #2 (permalink)
Defector
El Presidente's Avatar
Just do it like mine.
Old 09-25-2004, 11:28 AM   #3 (permalink)
Car: 2008 128i
already got the alarm. it just needs to be installed. I'm taking it to installer guy today and seeing if he will be able to replace/move the LED if not its off to electronics shop.
2008 128i Jetblack
Old 09-25-2004, 01:08 PM   #4 (permalink)
Defector
Dude, you bought a stellar and are having it installed?
Thats nuts. Specifically, what do you need to know? Just how to move to LED to someplace like the mirror?
To do that, cut the wire on the LED and extend it with any wire thats the same guage from radioshack. With the glovebox off, you can route it out of the side and under the weather stripping until you hit the pillar. You can with keep going under the weather stripping or put it uner the trim. Thats harder, but probably worth it. Either way, at the top, stugg if above the headliner and run it to the mirror. Take of the sunroof panel, drill a small hole, push the wires though, remove the mirror, drill the hole, use silicon to secure the LED, and you done.
Old 09-25-2004, 01:50 PM   #5 (permalink)
Car: 2008 128i
If i start pulling that much of my car appart I will break something. I couldnt figure out to to get into the pillar. and I need a new LED cause i broke the 1st one.
I got the 2 way stellar. and there is more than just plugging it in. I gotta find all kinds of fuckin wires and splice into them and mount shit up. and the wireing loom/harness for it is frigging huge... if you want to comeover and help that would be great but your a little far.
2008 128i Jetblack
Old 09-26-2004, 12:13 AM   #6 (permalink)
Defector
Current travel plans place in CA sometime in Janurary. IF you feel like a drive and wait, I'll be in SF.
Old 09-26-2004, 11:06 AM   #7 (permalink)
Car: 2008 128i
maybe I will come up with another project for around then. like an amp, sub, and el-pres e36 box.
2008 128i Jetblack
Replacing worn out Armrest on E36? Delmarco 3-Series (E36) 5 02-20-2005 04:44 PM
Replacing Headlamp Assembly NascarSigEp 3-Series (E46, E90) 4 11-06-2004 11:46 AM
Taillights With Leds Paraklas 3-Series (E21, E30) 12 10-28-2004 05:26 AM
Clear corners and LEDs jaavaajoe 3-Series (E46, E90) 3 07-27-2004 02:55 PM
is replacing ignition switch diy? ifonlyIhad 5-Series (E12,E28, E34, E39, E60) 0 05-31-2004 04:37 PM
