I bought my 1998 E36 328i about 3 months ago, and it has the premium sound package(also known as the Harmon Kardon system). Well recently, my front speakers have been giving me a screetchy noise when vocals or high treble play. I usually play any tech music, so of couse I want clarity in my music, but now this is happening and I have to know what to do....1. get rid of the speakers and get new ones(aka they are blown)...OR 2. replace the capacitors as I have heard for the regular nokia system...OR 3. do i have to just tighten a few bolts...OR 4. get a damn new head unit?
I hope I'm not the only unfortunate sucker to have this happen, so if I'm not and anyone knows what to do, please help a fellow BMW owner out
Originally posted by E36Propeller@Jul 29 2003, 04:49 PM Well recently, my front speakers have been giving me a screetchy noise when vocals or high treble play
That happened to me too....It was weird because it was like that for about a week then it just quit doing that ....maybe it will stop good luck
I have a solution, Do this at your own risk. You take either a rubber mallet or a 25lb. sledge, your choice (25lb. sledge recommended) you take a big back swing and aim straight for..........hmmm thats not the best idea, I don't know.
__________________ <img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
i kinda had this prob in my E46, i got a pro to do it. its very odd, what it was were the wires being in contact with some other part of the door. maybe this is something diff but o well.
is it an in-dash cd-player? if it a trunk FM modulated one you can get weirdness. also, the comment about the wire's gone awry could be true too. but if a wire is not connected properly, or is touching something it shouldn't, i don't know why you would see a response only in the high-end. frequently wire crosses or improper grounded etc result in what is call a 60 cycle hum. that 60 cycle hum is a base noise not isolated to just the high end. try to find out if the screaching is isolated to a single speaker, or if it is systemic. that might help isolate your problem.
The upper freq. tend to go as do the lower when I speaker gets tired. If you can remove your door panel and remove the speakers and take a look they might be dry rotted. I know my tweeter and 4" were both bad in my M3. The 5 1/4 was still fin down in the kick panel, which is usually the case because it isn't exposed to the elements the others are in the doors.
I replaced mine but also added a aftermarket in dash CD player, 4 channel amp and JL Audio's 8" stealth boxes. I am a manager at a car audio shop where I live so I have to have good audio.
MB Quart makes a nice direct replacement and JL makes one that requires a little work.
Good luck...
__________________ 1996 2 Door Black M3
H&R Springs, Bilstein Struts, X Brace, Intake. HKS Exhaust, 18X8 Wheels, and just a little bit of audio......
Originally posted by Black E36 M3@Aug 1 2003, 06:29 AM The upper freq. tend to go as do the lower when I speaker gets tired. If you can remove your door panel and remove the speakers and take a look they might be dry rotted. I know my tweeter and 4" were both bad in my M3. The 5 1/4 was still fin down in the kick panel, which is usually the case because it isn't exposed to the elements the others are in the doors.
Good luck...
yeah what he is saying is probably true. you will get nice sound with the MBQuarts. JL has good loudness as well
__________________ Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
My two pennies: Speakers are gone, replace with nice aftermarket. I have to agree with the crowd... MBQuart
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
Originally posted by Asio@Jul 29 2003, 06:18 PM I have a solution, Do this at your own risk. You take either a rubber mallet or a 25lb. sledge, your choice (25lb. sledge recommended) you take a big back swing and aim straight for..........hmmm thats not the best idea, I don't know.
that's the stanley murdoch principle: any job can be accomplished with the correct sized hammer.
also, in my 328is from '98...is that a HK speaker system and did alpine build the bmw stereo? someone put a crappy sony fm modulated 10 disc...i want to relpace it. should i go alpine head/in-dash or should i do the factory alpine 6 disc. the number of discs etc doesn't bother me. i would rather have quality. <_<
