Pre-wired cd changer?? - BMW Forum - BimmerWerkz.com
Old 12-26-2003, 03:13 PM   #1 (permalink)
rvisco45 is an unknown quantity at this point
Hey,
I was thinking of getting the Blitzsafe Auxiliary input for the 325i sedan 2003. I currently do not have a cd changer, but I understand that it is prewired. Where exactly are these wires located so I won't be ripping my trunk apart? I want to plug my portable Minidisc and MP3 player to the Aux converter, and has anyone else had experience with this product? Thanks!!
Ron
Blitzsafe site:
http://www.blitzsafe.com/blitz_catalog/bli.../blitz_bmw.html
rvisco45 is offline   Reply With Quote
Old 12-31-2003, 07:33 PM   #2 (permalink)
Im not sure about where the wiring in your model car would be, but if you dont have a cd changer, its most like rear of the trunk, drivers side. But again, im not totally sure with that model.
Also, be careful of this: portable devices are made to run with headphones, not be used on actual audio equipment, the gains will not match and you will have poor sound quality and or fairly low volume output. Try and find a cheap pre amp with a good 2v (min) output to hook up inline between the aux input and the portable device.
Old 01-01-2004, 09:20 AM   #3 (permalink)
showdown is an unknown quantity at this point
Im going this weekend to get the Blitzsafe adapter installed in my car for the ipod
showdown is offline   Reply With Quote
Old 01-01-2004, 01:44 PM   #4 (permalink)
Snowjob's Avatar
Snowjob is an unknown quantity at this point
this might be a really stupid question but it completely baffles me..
say someone has an e46 that doesn't have any cd player at all. as i've read, it seems that everyone's pre-wired for a trunk-mounted 6-disc player. Now lets say that person gets the 6 disc changer and connects the wires in the trunk... where on the dashboard would they control the functions (play, stop, etc.)?
Snowjob is offline   Reply With Quote
Old 01-01-2004, 02:46 PM   #5 (permalink)
Through the factory unit. THeres usually a CD button even in a car not equipped with a cd changer. Those wires all go to that and the stock dekc is used to control ALL functions of the changer, thats why only certain changers for certain model cars work without FM modulators and / or replacement of the deck.
Old 01-01-2004, 04:24 PM   #6 (permalink)
Snowjob's Avatar
whats the price range on the changers (99 323i) and 1-10 how hard is it to self install for someone that's not mechanically inclined?
Thanks.
Old 01-01-2004, 04:39 PM   #7 (permalink)
Snowjob's Avatar
and what's this about a liner and access door? I'm looking at http://www.ultimatebmwparts.com/cdchanger/...ackagedeals.htm
Old 01-01-2004, 08:51 PM   #8 (permalink)
These are fairly easy to install considering the holes for the screws are probably pre drilled too, even if they aren't, its still easy. And theres only two wires, just plug it in. the panels and access door is for the vehicles where the CD changer isnt in the open and goes behind a panel. (it is a replacement panel so you can still get to the "hidden" cd changer.)
Old 01-01-2004, 09:39 PM   #9 (permalink)
Snowjob's Avatar
hmm.. does that mean you can choose to have the changer hidden/not when you're installing it? Does the extra liner and kit from the site above just go around the spot where the changer would be and thus it's "hidden" but the brackets and all are still the same?
Price range, too please.
Old 01-02-2004, 10:02 PM   #10 (permalink)
Snowjob's Avatar
nobody know?
Cd Changer Problem In 325i **help** motown3 3-Series (E36) 0 09-25-2004 11:44 AM
Need Advice on CD Changer for 2003 325i atwnsw 3-Series (E46, E90) 1 08-24-2004 10:44 AM
OEM changer and head unit mystery BobCT Audio and Electronics 4 08-04-2004 11:50 AM
alpine unit with Pioneer changer - not working BobCT Audio and Electronics 14 06-28-2004 10:48 AM
