Power Supply? - BMW Forum - BimmerWerkz.com
Old 09-07-2004, 06:35 AM   #1 (permalink)
silvrbullet is an unknown quantity at this point
hey people,
im shortly installing 2 subs and an amp(maybe2). Will it be ok to run these off the battery (located up front) without draining it?
Cheers in advance
silvrbullet is offline   Reply With Quote
Old 09-07-2004, 09:40 AM   #2 (permalink)
Car: 2008 128i
why is your battery upfront?
2008 128i Jetblack
Old 09-07-2004, 10:24 AM   #3 (permalink)
mlomker is an unknown quantity at this point
Send a message via Yahoo to mlomker
Systems up to 500 watts usually aren't a problem but some people will add a capacitor to the system to ensure clean power for the subs. If you're going with a 1 KW+ system for that "can hear it a block away" sound then you'll need to consider a deep cycle battery (such as the Optima) or a second battery. You may want an upgraded battery regardless of power output if you listen to your system with the car off for any length of time.
I've had 500 watt systems in my last two vehicles and didn't do anything special for power--I just ran 4 gauge power off the battery to distribution blocks and 8 gauge to each amp.
I'm not sure if European cars are different, but in the States the battery is in the trunk on the passenger side--that makes wiring amps in the trunk relatively easy.
mlomker is offline   Reply With Quote
Old 09-07-2004, 01:30 PM   #4 (permalink)
Defector
El Presidente's Avatar
euro cars are wired up front. You wont have any issues, but for that much power and distance run 0-4guage wire.
New Hu Has No Power jshearer Audio and Electronics 3 12-30-2004 07:56 PM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
power pulleys, re they really that bad? the///man 3-Series (E36) 1 10-18-2003 09:12 AM
