Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 12-03-2007, 03:17 PM   #31 (permalink)
Photos: 0
320de46m47 is on a distinguished road
Thanks to your help I've come a long way
but if i forget the infinity basslink (which is a bit on the large side!!) can i adequately power a sub using the alpine amp somehow?
320de46m47 is offline   Reply With Quote
Old 12-03-2007, 07:12 PM   #32 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
I was thinking it has a built in amp. If not, there is a different way to wire the amps.
-There's no place like 127.0.0.1
-"Wheel Sucks"
Old 12-04-2007, 02:46 AM   #33 (permalink)
Photos: 0
Yes the basslink has a built in amp, but its a little large. can i put 4 speakers in to two channels (would mean no fader?) and then bridge the remaining two for a sub (smaller than the basslink)?
Old 12-04-2007, 06:11 AM   #34 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
The specs show that its 200w. That should be a pretty close match for your four channel midrange amp. You usually want a ratio of 3:1 or 4:1, sub power to midrange power. A sub requires much more power to get moving than a typical midrange speaker, for a number of reasons. One, it typically has a larger voice coil; two, as the frequency drops you require more amp to retain the same volume; three, the sub is typically place the furthest from your ears more power is required to overcome distance, there is more but you get the picture, all of which require more power. You Alpine is rated at 50x4, so your sub amp should be right on the money. Plus, Infinity has a good R&D department, they gear the sub, enclosure, and amp to all work together well. Bridging that Alpine will net you about the same power as what Infinity provides (+/- 10%, not enough to hear a difference. I saw where they have a 25A fuse on there, you'll probably want another piece of 8ga. for that amp as well, again fused at the battery at around 30A.
-"Wheel Sucks"
Old 12-05-2007, 03:35 AM   #35 (permalink)
Photos: 0
the problem with the basslink is really that its physically too big and will take up around a fifth of the boot space when seats up (e46 touring). this in itself wouldnt be too bad but when seats are down the whole flat load area is, well, no longer a whole flat load area. i had wanted to put it underneath the large panel and above the spare but the space is about 2 inches too shallow!! arghhhh! i made a mistake in my calculations. mind you it was only £46.
Old 12-05-2007, 06:03 AM   #36 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
Lol, this is the way my mind is working this morning. First thought was to make a false floor 2" higher all the way up to the back seat, so it would again be flat back there, but when you fold the seat down, it would drop 2" in front of your new floor. I'm not sure if you could take the sub out of its enclosure, reloacte the amp, build an enclosure similar to the one you showed earlier, and go that route.
-"Wheel Sucks"
Old 12-05-2007, 10:36 AM   #37 (permalink)
Photos: 0
interesting idea. i too thought about raising the floor panel on a frame around the edge underneath. dont really want to re-arrange the basslink components...might just sell it instead. ah well!
Old 12-05-2007, 01:57 PM   #38 (permalink)
Photos: 0
ive decided im going to look for another amp and sub. so what am i looking for...ideally 200watts rms you say? 2 channels? and a 10inch or 12 inch subwoofer or two? (the alpine is 4 x 40rms). what i think will do is cut out a sheet of mdf the same size as the original floor stick a hole in it build on to the back of it and then carpet it. that way if i ever want to sell the car i can just put the old panel back in.
Old 12-05-2007, 02:34 PM   #39 (permalink)
Photos: 0
the ratios 3:1 and 4:1 you mentioned....is that each speaker? i.e. as with 200w RMS (basslink) : 40 w RMS (alpine per channel)
Old 12-05-2007, 09:24 PM   #40 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
Yeah, the ratio is right (3-4 times the power for your sub than the mids). 200 RMS would be a nice setup for like a single 10 or 12". Just seal the MDF to the steel floor really well, so it doesnt leak air anywhere.
-"Wheel Sucks"
Old 12-06-2007, 05:21 AM   #41 (permalink)
Photos: 0
any 200 watt mono amp youd recommend? big range of prices from very little money up
Old 12-06-2007, 06:25 AM   #42 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
I've installed about a hundred of these, no issues of yet: Alpine Electronics of America, Inc. - MRP-M450
-"Wheel Sucks"
Old 12-06-2007, 08:43 AM   #43 (permalink)
Photos: 0
for thios kind of money would this be completely rubbish then?
1400 WATT SHARK CAR AMP AMPLIFIER NEW MOSFET TECHNOLOGY on eBay, also Multi-Channel, Amplifiers, In-Car Entertainment GPS, Cars, Parts Vehicles (end time 06-Dec-07 20:15:00 GMT)
Old 12-06-2007, 12:39 PM   #44 (permalink)
Photos: 0
http://forum.bmwcarmagazine.com/view...&highlight=sub
aiming a this...want to copy but im probably too lazy and not enough spare time
Old 12-06-2007, 05:25 PM   #45 (permalink)
Photos: 0
Page Not Responding
why is this so cheap? is it rubbish or ok?
vB code is On
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 11:23 PM
speaker and amp install MiguelACA Audio and Electronics 9 04-27-2007 04:19 PM
1990 518i - engine problems and advice for a novice!! RichardMichael 5-Series (E12,E28, E34, E39, E60) 6 02-08-2006 03:18 PM
How do you install amp and subs to a stock headunit? t5sesco Audio and Electronics 2 09-16-2005 02:26 AM
Need Advice on CD Changer Install Kit 2003 325i atwnsw 3-Series (E46, E90) 0 08-28-2004 05:56 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
