| This is discussed further somewhere, but if you used a harness to connect it. Check to see if you have the power antenna wire (Blue) connected to the blue wire on the harness insteed of the remote amp wire (Blue/White). If so then switch the connection.
I found the thread, it is further down this page. "Factory Remote Turn On"
Reason: Found reference fo statement
