New Installation??? - BMW Forum - BimmerWerkz.com
Old 07-13-2005, 10:11 AM   #1 (permalink)
Bunny Capricorn is an unknown quantity at this point
I have a 92'525 which I got with a after market radio running thru a harness thru the beamer factory amp. The problems is only the left side plays strong. When I move the balance to the right side I get a very week signal.
I recently changed my radio and I noticed that the job done behind the dash was very poor. Wires cut and mended everywhere like an ignorant person got a hold of it. At this point I'm not sure if its wired correctly to the after market deck or if the Amp is blown on the right side.
1. Is there a way I can test the factory amp?
2. Were is the factory amp located?
I just recently bought a 4 channel amp (for the 8 speaker system; no sub) to re-wire the whole car. Would this be my best bet and how difficult is it to run the wires for the front 6 speakers to the rear for my amp....and if so, what kind of Crossovers or Speakers with Crossovers should I use for the front.
Oh.....one more thing.......what size speakers go in the rear?
Thanks allot folks!!!
Bunny Capricorn is offline   Reply With Quote
Old 07-13-2005, 05:21 PM   #2 (permalink)
da_administrator
da_bull's Avatar
[snapback]361907[/snapback]
Yes, throw the factory amp in the fireplace this winter and use your new amp to run all 8 speakers. On a good note, look behind the carpet panel on the drivers side in the trunk. You will find the factory amplifier there. The wires will (should) be in a twisted fashion. These are all the wires going to each speaker. Hook these up to your aftermarket amplifier, and run a set (or two) RCA cables to your aftermarket radio.
It gets REAL goofy trying to incorporate your factory amp and an aftermarket one. Delete the problem child and you will have better sound. After you get your amp installed and your speakers are still low or absent, you may have a bad speaker. Just do one thing at a time and you'll be ok.
Hope that helps...
Old 07-15-2005, 11:31 AM   #3 (permalink)
I will try this da bull and get back with you.
Thanks!
Old 07-15-2005, 05:41 PM   #4 (permalink)
da_administrator
da_bull's Avatar
no problem, I'm here to help when I can...
Old 07-26-2005, 01:26 PM   #5 (permalink)
I strongly disagree about him having better sound. How is he going to have better sound with no crossovers?
He needs to get (or build) a set of crossovers. Even if they consist of just "bass blockers" - its better than nothing. Throwing out your factory amp while keeping factory speakers is a bad idea - because in the amp is an essential part of the speaker system (the crossovers)
It's real important that you keep those! Simply hooking the old speakers up to the new amp will sound pretty much like crap.
Old 07-26-2005, 03:35 PM   #6 (permalink)
Ok folks.....Question time now. How do I get all six component speakers plus my two rear speakers hooked up to a four channell amp????
I keep hearing about this "crossover".....will this bind my front six so all I have is two left and rights coming from the front?
Come together like Voltron with some knowledge for ya' boy please!!
Thanks!
Old 07-26-2005, 03:40 PM   #7 (permalink)
Yep. theres part of the crossover problem. Lack of crossover does not allow this.
You NEED one.
Basically, all you can do is hook up the woofers and leave the tweeters disconnected.
That'll surely sound fairly crappy.
Choices are
: another factory amp
: build or get some crossovers from ebay, etc, etc
: run only the woofers
: get new front and rear speakers.
even if you COULD just wire the pairs of speakers together, if your amp isn't 2 ohm stable, you'll have heat issues with that thing after a long period of time (probably not a major concern either way since your not driving subs, power hungry drivers, etc) AND the bass frequencies hitting the tweeters will blow them.
Bilstein PSS suspension installation E36 325I 3-Series (E36) 2 11-05-2005 01:48 AM
Clarion AutoPC Installation Help mostwired Audio and Electronics 2 05-02-2004 10:28 AM
