Need a amp diagram... - BMW Forum - BimmerWerkz.com
Old 11-18-2006, 03:17 PM   #1 (permalink)
Fresh Cut Vegetables is on a distinguished road
for a '93 325i w/10 speakers. I'm not sure if its the HK package...but the rear speakers are crappy paper Nokias, so i'm going to assume its not. The amplifier is a blaupunkt and it has 2 connectors, both with 12 pin. I know of Furious' diagram (http://www.bimmerwerkz.com/forum/aud...tml#post427828
My two connecters are like the one thats shown underneath the HU connector. Anybody could help me out, it'd save me loads of time. Thanks
Fresh Cut Vegetables is offline   Reply With Quote
Old 11-18-2006, 07:53 PM   #2 (permalink)
Also, does anybody know the difference between the Blaupunkt Bahamas MP46 (Blaupunkt - Receiver - MP3 Tuners - Bahamas MP46) and the Key West MP36 (Blaupunkt - Receiver - MP3 Tuners - Key West MP36)? I've check the specs, everything is identical however, there is a 20-30 price difference...
This forum needs an "Edit" button...
Old 11-18-2006, 09:13 PM   #3 (permalink)
da_administrator
da_bull's Avatar
What are you trying to do? If you're installing a headunit, I'd buy the wiring harness to install. It makes it WAY easier to do.
The edit button is only available for like 10 minutes or something...
Old 11-18-2006, 11:20 PM   #4 (permalink)
Wiring diagram for the amplifier...i guess the 2nd post was rather confusing. On the second one, i just want to know what the difference is. The specs looked identical and the unit itself looks the same... But yeah, the wiring diagram for my amplifier which has two 12 pin connecters
Old 11-19-2006, 11:29 AM   #5 (permalink)
bump?
Old 11-19-2006, 09:02 PM   #6 (permalink)
nobody?
Old 11-19-2006, 09:09 PM   #7 (permalink)
da_administrator
da_bull's Avatar
Most of the amps that have that plug (that I've seen) are the same configuration. Use that picture just as a reference (a good starting point), but double and triple check all the wires before hooking an amp or headunit up. It is more than likely the same confiruation, but always make 100% sure so nothing will burn up. BTW, typically, the speaker wires are a twisted pair too.
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
AMP connection problem?? topless_328 Audio and Electronics 3 12-02-2005 10:08 PM
Forget speaker upgrade, go for an amp Jon G. Audio and Electronics 1 11-26-2005 01:08 AM
need wire diagram of plug at hk amp bbullet421 Audio and Electronics 1 11-16-2005 09:06 PM
hk amp bad? bbullet421 Audio and Electronics 1 11-15-2005 09:28 PM
