is my 2 channel amp good or will i need a 4 channel - BMW Forum - BimmerWerkz.com
post #1 of 23 (permalink) Old 12-31-2005, 03:10 PM Thread Starter
B3M2W5i's Avatar
B3M2W5i is an unknown quantity at this point
Send a message via AIM to B3M2W5i
of so heres the specs of what i have i was wondering if the amp is good for my set up or if you guys could recommend a 4 channel amp
5 1/4 components
250 watts max/125 rms
80hz-20khz
90 db
rear 6x9
500 watts max
30hz-30khz
97 db
amp
550 watts
2 channel
i also have a clarion pro audio head unit DXZ555MP
thanks guys all this stuff has just been sitting around waiting to get in my car for some time..
Cashmere Beige Metallic
B3M2W5i is offline
post #2 of 23 (permalink) Old 12-31-2005, 08:36 PM
WOT in Reverse
jllphan's Avatar
jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute
Depends. Wattage by itself doesn't mean a lot. I've heard 20w/ch amps that are loads louder than 100w/ch amps. THD and S/N ratio are as important. Provided your amp is two ohm stable, you should be able to run that speaker system fine, but you won't have any fade control i.e. you won't be able to adjust the balance from front to rear.
A good four channel amp (.02THD or so) of 50W/ch would be a better plan as it would run at 4ohms and wouldn't generate as much heat thusly sounding better at high volumes and ultimately lasting longer.
jllphan is offline
post #3 of 23 (permalink) Old 12-31-2005, 11:01 PM Thread Starter
B3M2W5i's Avatar
so how would i wire it up? split some wire or what?
B3M2W5i is offline
post #4 of 23 (permalink) Old 01-01-2006, 08:12 PM Thread Starter
B3M2W5i's Avatar
quote myself please help me out here..
B3M2W5i is offline
post #5 of 23 (permalink) Old 01-02-2006, 05:26 PM
da_administrator
da_bull's Avatar
da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute
A four channel amp should have four inputs and your headunit should have 4 outputs. Just run two sets of rca cables from the headunit to the amp and run 4 speaker wires to the existing speakers. It'll be more flexible that way.
da_bull is offline
post #6 of 23 (permalink) Old 01-02-2006, 05:29 PM Thread Starter
B3M2W5i's Avatar
sounds right but how could i do it if i want to use my 2 channel amp?
B3M2W5i is offline
post #7 of 23 (permalink) Old 01-03-2006, 05:33 AM
da_administrator
da_bull's Avatar
Just wire in the left (front and rear) to the left channel and the same for the right side. You wont have a fader (F/R) but you will still have your correct L/R stereo music. Its not that big of deal (fader) its just that you front and rear speakers will get the exact same power. So if your rears (6x9"ers are typically louder than smaller ones, 90db compared to 97db in your case) are louder you dont get the benefit of making them quieter to match. Thats the flexibility I was speaking of.
Hope that helps...
da_bull is offline
post #8 of 23 (permalink) Old 01-03-2006, 07:10 PM Thread Starter
B3M2W5i's Avatar
how could i wire it? are there special types of wires or a splitter of some sort?
B3M2W5i is offline
post #9 of 23 (permalink) Old 01-03-2006, 10:13 PM
da_administrator
da_bull's Avatar
not really just run the front left speaker to the left channel of the amp, then run the rear left speaker wire to the same two screws on the amps left channel
da_bull is offline
post #10 of 23 (permalink) Old 01-03-2006, 11:53 PM Thread Starter
B3M2W5i's Avatar
thanks. got any tips on instaling a head unit?
B3M2W5i is offline
post #11 of 23 (permalink) Old 01-04-2006, 07:43 PM Thread Starter
B3M2W5i's Avatar
one last thing... i think i may just stick with the original wires to prevent myself from having to wire everything.. how could i wire an aftermarket head unit to work with the original speakers?
B3M2W5i is offline
post #12 of 23 (permalink) Old 01-04-2006, 10:15 PM
da_administrator
da_bull's Avatar
that would be fine, you can actually get all the individual speaker wires at the factory amplifier thats in the trunk more than likely on the drivers side.
da_bull is offline
post #13 of 23 (permalink) Old 01-04-2006, 10:21 PM Thread Starter
B3M2W5i's Avatar
i would still have a factory amp even if i have the nokia speakers?
B3M2W5i is offline
post #14 of 23 (permalink) Old 01-05-2006, 05:03 AM
da_administrator
da_bull's Avatar
There should be one, I havent seen a 325 yet that doesnt. Dont get too excited about it though, its only like 10-12 watts per channel RMS. ANY aftermarket amplifier will sound/perform better.
da_bull is offline
post #15 of 23 (permalink) Old 01-15-2006, 02:00 AM Thread Starter
B3M2W5i's Avatar
ok last thing really! head unit mounting and installing so easy and obvious i shouldnt even ask or will it be harder than i think?
and btw i took a look at the amp and icant figure out the harness and where everything connects to..
B3M2W5i is offline
  BMW Forum - BimmerWerkz.com > General Category > Audio and Electronics
Help! Offered a deal on 1993 325 - good year/deal? Pangris 3-Series (E36) 19 11-15-2007 06:49 AM
To all BMW gurus . . . is this a good deal? bdonkersgoed 5-Series (E12,E28, E34, E39, E60) 10 05-29-2004 12:48 PM
good sites for m5s? bimmerM5e39 M-Series (M1, M3, M5, M6) 1 11-28-2003 09:27 AM
What are the good BMW aftermarket companies. B.D Bimmer Talk/Motorsports Talk 4 10-01-2003 07:55 PM
