Mp3 Decoder On Professional Gps (e87) - BMW Forum - BimmerWerkz.com
Old 10-27-2004, 12:58 PM   #1 (permalink)
Scrounch is an unknown quantity at this point
Hello,
Does anyone know how to read a MP3 CD on the Professional GPS for 1-series (E87).
What are the requirements for burning such kind of CD :
- CD-R or CD-RW
- finalize the CD or not
- format of song name : name length, spaces allowed ?
It works with normal audio burning (Wav) but a data CD with MP3 files does not work.
The technical data sheets shows a MP3 decoder.
Thanks in advance for ur help.
Scrounch
Scrounch is offline   Reply With Quote
Old 10-28-2004, 08:22 PM   #2 (permalink)
WOT in Reverse
jllphan's Avatar
Always finalize a disc. A CDR and CDRW only differ in that the CDR is one write only, meaning you can't reuse it. You can replace the information written to a CDRW. Finalizing a CD is what writes a T.O.C or Table of Contents to the disc. This is what tells a CD Player: how many tracks, where they are divided, and any other pertinent information (CD Text, etc. etc.). If the disc isn't finalized, the deck doesn't know how to play the CD or what's on it.
That being said, maybe your deck isn't compatible with an MP3 incoded information. Have you tried a few different brands of media? As different companies have different opinions on the respective reflection properties, dyes differ from company to company and certain dyes work better with certain cd players. You can identify the difference between various dyes by the color on the underside of the disc. You'll just have to experiment.
If your deck plays a CDR with WAV. info consistently regardless of brand of CDR, but have no luck with MP3 info, you just have a defective technical data sheet.
Old 10-29-2004, 07:33 PM   #3 (permalink)
Each CD burned was made with the Finalize option selected.
For the test, I use different brands with no results.
On a CD-RW, when I burn a WAV CD, it works. But when I burn a MP3 CD with the same CD-RW, it does not.
I think u r right, this CD player does not support MP3 CD.
Thank u for yr help.
Scrounch.
