Mounting speakers in E39 door panels - BMW Forum - BimmerWerkz.com
Old 09-07-2005, 12:46 AM   #1 (permalink)
Jon G. is an unknown quantity at this point
I have a set of Focal 5-1/4" woofers that I need to mount in the doors of my '02 530i. But it turns out that these speakers are too deep to mount in the factory pod.
Have others run into this problem? How else can the speakers be mounted?
I have noticed a few other annoyances:
-the factory grille is actually smaller than the face of a 5-1/4" speaker, is there any audible affect to this overhang?
-if you "top mount" the woofer to the door panel the aftermarket grille interferes with the other door features like the arm piece.
-as above, but if you move the speaker down the the door panel then, as it conforms to the contour of the door, it actually points downwards towards the floor. Again, is there a sonic problem with the orientation?
It seems that a very simple speaker upgrade is turning ugly!
-Jon
'02 530i
'03 SVT Cobra Mustang
Jon G. is offline   Reply With Quote
Old 09-07-2005, 07:34 PM   #2 (permalink)
billB's Avatar
I hope you will find better answers here.....Good luck
regards
billb
Old 09-07-2005, 09:53 PM   #3 (permalink)
da_administrator
da_bull's Avatar
Mounting the speaker in a factory pod is usually the most solid mounting. They are usually plastic and can be modified relatively easily.
The opening in the grill should be 70-75% of the speaker size (i.e. 5.25" speaker should be 4" or bigger)
Pointing the speaker towards the floor will destroy your sound stage. It will make the singers sound like they are underneath your seat.
hope that helps....
Replace Rear Speakers Of 1994 325i Convertible kvrr79 Audio and Electronics 3 11-11-2004 09:09 PM
need helps replacing speakers noamkrief Audio and Electronics 1 09-12-2004 09:20 PM
Questions about E39 speakers mrogers Audio and Electronics 4 04-03-2004 09:36 PM
Horrible Sound with new speakers Ronny Audio and Electronics 22 01-16-2004 02:56 PM
