Installing a sub amp... - BMW Forum - BimmerWerkz.com
Old 03-28-2004, 10:36 PM   #1 (permalink)
Slvr e39's Avatar
Car: Dinan Stg 1 M3
Slvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond repute
Send a message via AIM to Slvr e39
Post
I have a 1998 528i and I want to put a sub amp in the trunk. Seeing that the battery is in the back I thought that the power aspect would be very easy so I am going to install it myself. I have heard that you can tap in to the factory wires and get a bass signal. Where can I get the signal for the remote amp power on and where do I tap in to get the bass signal? Also, do I need a wiring harness to convert the signal to rca?
thanks
Dinan Stg 2 Phoenix Yellow M3
Slvr e39 is offline   Reply With Quote
Old 03-28-2004, 11:04 PM   #2 (permalink)
Car: 2008 128i
get an amp that can take highlevels to and then push to a sub. and tap the speaker wires for signal. thats the easy way.
the harder way involves much more messing with the amp and wiring... there is some good info here in the audio form about the 5 series and how to do some of these things or how to avoid it.
You may see if bav auto has a bass link for your ride. That would be plug-n-bump.
2008 128i Jetblack
Old 03-28-2004, 11:59 PM   #3 (permalink)
Slvr e39's Avatar
Car: Dinan Stg 1 M3
Do you know what color the bass signal wire is?
Old 03-29-2004, 11:03 AM   #4 (permalink)
WOT in Reverse
jllphan's Avatar
no offense, but i wouldn't recomend this set up. High level inputs are weak and low fidelity. This is what i would do...
Buy a line level converter (this changes speaker level to line level). Directions for use should be included in the package (it is pretty strait forward). Tap into the factory amp turn lead (you can use the violet wire, it will work).
You now have RCA's and a remote wire. All that is left, is to run your power wire (in trunk), find a good ground (in trunk), and hook up your sub.
...if none of this makes sense, let a professional do it. It is easy, but not extremely easy.
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
For sale 12" Apline Speaker and 1400 Watt Amp scottm3 Audio/Miscellaneous Auto Parts 4 03-31-2006 09:53 PM
AMP Power cable! 316i e36 94 Butterfingers Audio and Electronics 1 10-09-2005 08:44 PM
installing bass blockers buuhh99 Audio and Electronics 1 09-20-2005 05:13 AM
How do you install amp and subs to a stock headunit? t5sesco Audio and Electronics 2 09-16-2005 01:26 AM
