Installing An Amp - BMW Forum - BimmerWerkz.com
Old 06-28-2005, 08:23 PM   #1 (permalink)
tbhtjd is an unknown quantity at this point
Send a message via AIM to tbhtjd
I recently replaced my head unit and speakers and I want to add a 4-channel amp to give the speakers some more power. When I wired the head unit I used the stock fader so I only used the front left and right positive outputs. I found the stock amp in the trunk.
Alright, with that said, when I install the new amp can I just use the wires from the stock amp? Also, should I leave the positive connections from the head unit? Is the head unit really supplying any power with the amp connected?
Thanks in advanced.
TBHtjd
1987 535i
tbhtjd is offline   Reply With Quote
Old 06-29-2005, 05:29 AM   #2 (permalink)
da_administrator
da_bull's Avatar
If the factory amp is connected, then you are correct in that the headunit really doesnt supply anything more than a signal for the factory amp to use. In order to use an aftermarket amp, you will have to find the wires coming from the output of the factory amp going to the speakers, cut them (that gets rid of anything the factory amp does), and hook them up to your new amp.
Hope that helps.....
Old 07-20-2005, 06:40 AM   #3 (permalink)
JayKayNZ is an unknown quantity at this point
Cool, so does that mean if I can bear the crappiness of the original amp in my '87 735i e32, if i put a new headunit in, it wont fry the amp? (as im presuming the old h/u has a lot lower power output compared to the the h/u)
JayKayNZ is offline   Reply With Quote
Old 07-20-2005, 11:13 PM   #4 (permalink)
da_administrator
da_bull's Avatar
[snapback]363739[/snapback]
No, it wont blow your factory amp. The factory amp takes what is called a high level (speaker level) input. An aftermarket usually uses a low level (RCA level) input. You can feed your factory amp with the aftermarket radio.
But if your car is almost 20 years old, youd get better performance from a deck and rewiring. I like to rewire and get rid of the amplifier, but thats just me. I would rather have the power from an aftermarket radio (a decent one, mind you) or a small aftermarket amp running the factory speakers.
hope that helps...
Old 07-21-2005, 08:31 PM   #5 (permalink)
Cool thanks for that. Got the sounds going ok, tho I still need a noise suppressor cos im gettin engine frequencies in one of the tweeters.
Sorry, i know im kinda doing this topic to death, but is the factory sound system (in the e32s) a 4ohm system? If i install a new standard smallish amp, will the original speakers be compatible with it?
I presume the 5" and 3/4" speakers (of which there are 4 pairs) are working parallel, and am guessing both would have to be taken out, and replaced by a standard 4ohm two way speaker. But of course up front, that means the door tweater would have to be bypassed, and a twoway put in in the kick panels. Is this correct?
Old 07-21-2005, 09:14 PM   #6 (permalink)
da_administrator
da_bull's Avatar
[snapback]364241[/snapback]
I would hold off on the noise suppresor. After you install the new amp you will probably find you dont need it. It may be in your amp since its only in one tweeter.
Make sure to get one that has a built in cross-over, the smaller speakers really need it. Most of them nowadays come with it anyways. High pass it around 80-125 hz and you'll be fine. Of couse then you'll need a sub to get the 100hz and down.
You are correct in your above assumptions, btw...
Old 07-23-2005, 06:23 PM   #7 (permalink)
dablack is an unknown quantity at this point
Originally posted by da_bull+Jul 21 2005, 10:14 PM--><div class='quotetop'>QUOTE(da_bull @ Jul 21 2005, 10:14 PM)</div><div class='quotemain'><!--QuoteBegin-JayKayNZ@Jul 21 2005, 08:31 PM
[snapback]364251[/snapback]
[/b][/quote]
i fried my amp in my 1991 525i/m50 ghead so how do I hook the Hifonics up with rca plugs?? splice into the black connector or the white one?
I am SO lost and confused now
and sorry which colour wires for front and rear
much appreciated in advance
Great board btw awsome community
dablack is offline   Reply With Quote
Old 07-23-2005, 11:49 PM   #8 (permalink)
da_administrator
da_bull's Avatar
to the forums
do you have a factory or aftermarket deck? you dont want to do any splicing regardless of which you have. If its factory they make line out convertors that safely take a speaker level signal and turn it into an RCA level signal.
Old 07-24-2005, 12:55 PM   #9 (permalink)
no it is a factory deck the oem amp is done where do you get line out connectors Ive never heard of them.....I was at e34.net and they recomend the splice technique...thanks for your help da_bull
Old 07-24-2005, 05:59 PM   #10 (permalink)
da_administrator
da_bull's Avatar
[snapback]364812[/snapback]
your local car audio shop should have them, ask for a "line out convertor". This will give you RCA connections from a speaker wire. The splicing method will give you a chance to be in a market for a new radio.
Old 07-26-2005, 01:22 PM   #11 (permalink)
Old 08-06-2005, 12:51 AM   #12 (permalink)
Edit: new thread
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
For sale 12" Apline Speaker and 1400 Watt Amp scottm3 Audio/Miscellaneous Auto Parts 4 03-31-2006 09:53 PM
AMP Power cable! 316i e36 94 Butterfingers Audio and Electronics 1 10-09-2005 08:44 PM
installing bass blockers buuhh99 Audio and Electronics 1 09-20-2005 05:13 AM
How do you install amp and subs to a stock headunit? t5sesco Audio and Electronics 2 09-16-2005 01:26 AM
