I Got A Kicker 5 Channel Amp Can I....? - BMW Forum - BimmerWerkz.com
Old 11-10-2004, 11:58 AM   #1 (permalink)
/Banned
MaddenMaster is an unknown quantity at this point
this is my system: kicker 5 channel amp running a polk component system in q-pods, 12" Kicker L5, i was wondering if i could ditch the single L5 and run 2 12" CompVR off that same sub channel without any problems
MaddenMaster is offline   Reply With Quote
Old 11-12-2004, 12:25 AM   #2 (permalink)
WOT in Reverse
jllphan's Avatar
I really wouldn't recomend either. An L5 or two CVR's is quite comparible in SPL. However, either set up requires an abundance of power that the sub channel on a Kicker 5ch amp won't provide.
If you want two CVR's or one Solobaric, get a bigger amp for the sub(s). Personally, I would run one CVR off the sub channel and be done with it. You'd be suprised how much bass you can get with one properly powered sub. Most kids are disapointed by a lack of bass, because they don't have enough power going to a pair of beefy (and inefficient) subs.
BTW, nice selections. I have been a dealer of all the aforementioned for over a decade and would highly recomend all that stuff
Old 11-12-2004, 09:44 AM   #3 (permalink)
/Banned
okceezy405 is an unknown quantity at this point
ive got the L5 in right now and it pounds the shit out of my car, but i gotta have more, i dont know why but i do, you know how it goes
what if i put in (2) 2ohm 10"compvr
okceezy405 is offline   Reply With Quote
Old 11-13-2004, 11:59 PM   #4 (permalink)
WOT in Reverse
jllphan's Avatar
[snapback]229274[/snapback]
A single L5 is to best served to be wired in a 2ohm config and given a mono ch of amplification (not derived from bridging two channes ala dual mono configuration as most people may think).
(2) dvc 4ohm CVR's wired into a 2ohm config would be best mated to a 2CH amp. And while they are flexible enough to be used with your sub channel, your amp realistically won't drive two CVR's to their potential.
The L7 however can handle significantly more power than an L5, and doesn't take up the trunk space of a dual sub set up.
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
For sale 12" Apline Speaker and 1400 Watt Amp scottm3 Audio/Miscellaneous Auto Parts 4 03-31-2006 09:53 PM
AMP Power cable! 316i e36 94 Butterfingers Audio and Electronics 1 10-09-2005 08:44 PM
How do you install amp and subs to a stock headunit? t5sesco Audio and Electronics 2 09-16-2005 01:26 AM
Fading Stereo Channel mtarchal 3-Series (E46, E90) 3 05-06-2004 03:57 PM
