Hu Install Problems - BMW Forum - BimmerWerkz.com
Old 03-03-2005, 07:50 PM   #1 (permalink)
tcompton2 is an unknown quantity at this point
Send a message via AIM to tcompton2
Hey ive been trying to install my head unit (Alpine 9847) in my 1995 325is (e36).
Here's what happened: After first attempt, the radip played fine, but cd's didnt play, and the head unit lost all presets and time whenever i turned off the car. Then i called crutchfield and followed thier instructions, switching the blue wire with the blue wire with stripe, and some other random things. NOW, i cant turn the head unit on at all. The fuse for the head unit, or the car is not blown.
Any ideas what the problem is? Is there a common BMW audio problem I am overlooking, I am a newbie haha.
Thanks guys.
95 325is
-aFe Intake-
-Tint/Clear Corners-
-H&R Springs-
....More to come....
<img src='http://www.suternet.net/uploader/uploads/325sig2_Group%201.gif' border='0' alt='user posted image' />
tcompton2 is offline   Reply With Quote
Old 03-03-2005, 08:05 PM   #2 (permalink)
TMac325is's Avatar
i had the EXACT same problem you did, but then i took the stereo back out, and rechecked all the connections and THEN it worked. so look over the schematics, and make sure all the connections are solid
Old 03-03-2005, 09:43 PM   #3 (permalink)
da_administrator
da_bull's Avatar
Check for power on the red and the yellow wires with a multimeter (or testlight...*shudders at the word*). Check to make sure you have a good ground. The losing presets at your first attempt can either be a bad/poor ground or the yellow wire doesnt have power when the key is turned off. Did you get the adapter harness to plug it in, or are you cutting the factory harness?
Old 03-04-2005, 09:19 PM   #4 (permalink)
WOT in Reverse
jllphan's Avatar
da bull hints towards the problem. If you loose your presets, your constant power lead is not properly connected (it's the yellow lead on some head units, and red on others). As for radio but not CD sound, it's because you didn't hook up your amp turn on wire. Make sure that both the blue, and blue/white striped wire are connected properly.
Here's a wiring skematic that may help you in your diagnosis...
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
Aftermarket Radio Install Problems blk325is Audio and Electronics 9 05-02-2004 11:46 AM
95 525 Deck install Problems ShowTime 525 Audio and Electronics 0 08-27-2003 01:27 PM
