hk amp bad? - BMW Forum - BimmerWerkz.com
Old 11-15-2005, 04:03 PM   #1 (permalink)
bbullet421 is an unknown quantity at this point
Send a message via Yahoo to bbullet421
Unhappy hk amp bad?
I replaced my stock HU with an Alpine cda-9831 about a year ago. I also have a n alpine sub and amp connected. Today, I seem to have lost the signal or power going to the factory amp. The sub is still putting out, but I am hearing nothing out of the other speakers. I checked the wiring from the HU to the wiring harness<no loose wires> How can I check to see if I have blown/burnt the stock amp or if its just a signal problem? Also I checked the 'radio' fuse under the hood<ok> Any ideas?
bbullet421 is offline   Reply With Quote
Old 11-15-2005, 09:28 PM   #2 (permalink)
da_administrator
da_bull's Avatar
check the power output of the radio (hook up a known good speaker to the speaker outputs). this will let you know if the Alpine's speaker outputs are working or not. if this is good, the stock amp may be bad. im not sure if a quick and easy way to check it. My advice would be to just bypass it if the speaker outputs still work. Depending what year your car is it should perform a little better than the stock amp. You will need some sort of crossover to remove the bass frequencies from the factory speakers, or they wont last long.
hope that helps...
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
Bad idle when Engine is HOT only!! Paraklas 3-Series (E21, E30) 0 11-14-2005 03:04 PM
AMP Power cable! 316i e36 94 Butterfingers Audio and Electronics 1 10-09-2005 08:44 PM
How do you install amp and subs to a stock headunit? t5sesco Audio and Electronics 2 09-16-2005 01:26 AM
