| moving to audio...
and if your 99 is an e36, then you shouldnt need a kit; the sleeve should work fine. My headunit was also a tight fit, but the supplied sleeve worked fine.
If your 99 is an e46, then yes, you most likely need a kit.
2000 MR-S Roadster= Current</span></span> |
