Okay, i'm close to getting this hooked up, but I really need some info.
This wiring is giving me a headache.
Ok, i'm trying to figure out how to hook this up.
On my stock wiring, there's a square plug with two wires going to it.
It says +12v on it. Where it plugs into the radio, it says the top wire is Ground, and the second wire is the ignition..... now why the hell does it say +12v on the top if it's ground? Is that just saying it's a 12v ground?
Okay, moving on to the second headache factor. There's a molex connector with two wires going into it. On the stock radio, where the yellow and white wires go into a hole, it says "Battery".
Where do those wires go, and what do I hook them up to.
Thanks for the help.
