Front Door Panles With Airbags - BMW Forum - BimmerWerkz.com
Old 09-23-2004, 09:32 AM   #1 (permalink)
David_04_325i is an unknown quantity at this point
I'm thinking of replacing all the speakers in my 2004-325i.....Really would like a better sound. I'm all hyped because i'm a "do it myself type of guy", then i realized while driving home one day, my front doors have the airbags. Will removing the door panels affect the airbags at all....really don't want them deploying on me...it would be costly to repair and set me well back on getting my project done....
Any response would be greatly appreciated....
David_04_325i is offline   Reply With Quote
Old 09-23-2004, 10:24 AM   #2 (permalink)
mlomker is an unknown quantity at this point
Send a message via Yahoo to mlomker
Not a problem, the airbags stay on the door when the panel is removed.
I had a little trouble figuring out where all the screws were, so you might want to check out this picture. The screws are hex heads and you'll probably want the T-handle style driver since some of them are deep.
A previous mechanic had already scratched up my doors (probably replacing a window regulator), but the panels are easily removed by prying up on a corner using a large flat-blade screwdriver wrapped in a towel.
I'm just in the process of cleaning up/finishing my install in an `01 325xi. If you have any questions then fire away and I'll help you out.
mlomker is offline   Reply With Quote
Front Drive Shaft Loose On 325xi bmw_in_maryland 3-Series (E46, E90) 4 01-13-2005 06:44 AM
E46 Wire Guides (complete) EcianIce Audio and Electronics 2 09-26-2004 07:40 PM
Help wiring up amp install lude69 Audio and Electronics 13 08-15-2004 10:24 AM
Another worthy competitor to the 3-series? AZ325Ci Other Rides 9 10-23-2003 06:08 PM
