Factory Remote Turn On - BMW Forum - BimmerWerkz.com
Old 04-20-2005, 06:06 PM   #1 (permalink)
323ic is an unknown quantity at this point
i have a 96 328i and i am in the process of putting a screen in it and when it comes on no sound will come out. i used a adapter from circuit city. they said that its probly the factory amp isnt turning on. and there are wires in stock harness that arent in the aftermarket so i think i need to find out which wire is the turn on for the factory amp so that i can turn it on with the remote wire. if im wrong just let me know.???
323ic is offline   Reply With Quote
Old 04-20-2005, 07:38 PM   #2 (permalink)
polaris448's Avatar
polaris448 is an unknown quantity at this point
The wiring harnes that i used had the remote wire and the antenna wire reversed. So I just used common sense and it has worked out for me.
polaris448 is offline   Reply With Quote
Old 04-20-2005, 09:24 PM   #3 (permalink)
no i need to know what color the wire is to the FACTORY amp is not a remote lead to an aftermarket amp.
Old 04-20-2005, 09:49 PM   #4 (permalink)
da_administrator
da_bull's Avatar
This one is for most amplifiers. Make sure to test the wire before assuming that it is 100% correct.
In your harness there should be a blue/white wire that will turn on the amplifier, and a blue wire that will raise/lower your power antenna, both of these wires need to be hooked up for those functions to work.....Hope that helps
Old 04-24-2005, 02:18 PM   #5 (permalink)
ADS328 is an unknown quantity at this point
[snapback]335681[/snapback]
remote turnon is white. you'll find it on the harness behind the left trunk panel.
<span style='color:blue'>The ONLY place to go for high-end audio equipment for your E36 or E46 BMW is <span style='font-size:11pt;line-height:100%'><a href='http://www.bavariansoundwerks.com/index.php' target='_blank'><span style='color:red'>Bavarian Soundwerks</span></a></span> BMW enthusiasts who also are audiophiles. They're the best! (No, I do not work for them, nor am I affiliated with them in any way.)</span>
ADS328 is offline   Reply With Quote
Key remote interboss 3-Series (E46, E90) 9 09-15-2005 05:49 PM
Factory Remote Wire 323ic 3-Series (E36) 4 04-20-2005 09:59 PM
Anyone Have A 3 Button Remote For Factory Alarm Fo nightkrawler 3-Series (E36) 5 09-27-2004 02:06 PM
remote turn on for amp. mole Audio and Electronics 8 06-02-2004 03:50 PM
