Factory CD Changer is not working!! help me please - BMW Forum - BimmerWerkz.com
Old 05-14-2004, 12:07 PM   #1 (permalink)
Graphic Designer's Avatar
Graphic Designer is an unknown quantity at this point
Send a message via AIM to Graphic Designer
the changer is in and ejects properly but back up front when i hit cd, the screen says "NO DISC"
Can someone tell me what is wrong?
00 328i no HK system. tape player up front.
Graphic Designer is offline   Reply With Quote
Old 05-14-2004, 12:24 PM   #2 (permalink)
Car: 2008 128i
be sure the changer cassett is in one piece. I've heard a tab or 2 can break off and cause problems.
2008 128i Jetblack
Old 05-16-2004, 02:05 AM   #3 (permalink)
i pulled the whole changer set up out even the brackets.
i didnt see no broken tabs anywhere. and it still doesnt work.
Old 05-16-2004, 02:10 AM   #4 (permalink)
WOT in Reverse
jllphan's Avatar
i think 007 was talking about the cd cartridge. Anyways, if the unit is saying NO CD then either the cartridge is not fitting correctly (broken tabs) or the unit is not recognizing the cartridge.
When you load, does it make all the noises like the cartridge is going in, and locking? When you choose a disc does it make a loading noise (i bet it doesnt, just sits there) ?
Old 05-16-2004, 09:12 AM   #5 (permalink)
yeah. the cartridge ejects correctly and when i put it in, it sounds like it locks. but thats all i can see that works. Nothing up front still wont activiate any part of the cd changer.
i have bought a magazine directly from the dealer and one online. neither display "NO DISC"
when we bougth the car, the changer was already installed but the previous owner must have taken the magazine(cartridge)
Old 05-16-2004, 12:22 PM   #6 (permalink)
roguesniper1's Avatar
Car: 97 528i and 94 325i
roguesniper1 is an unknown quantity at this point
Send a message via AIM to roguesniper1
It has nothing to do with CD magazine. Your cd laser is shot. Kaboom, Gone. You can fix it yourself if you know "how to swap the laser module" with a new one. It is the same one used in any cd changer, aftermarket or not. When mine went tits, I swapped it with one from Acura's cd changer. If you have no idea what I am talking about it, then it is highly recommended to get it done professionally. It shouldn't cost you more than $100 bucks.
PS: May be you can afford a new one from the money you are going to save from May 19th boycott.
roguesniper1 is offline   Reply With Quote
Old 05-16-2004, 02:42 PM   #7 (permalink)
Defector
El Presidente's Avatar
Before you go that route, have you disconnected the power cord and signal cord?
If there is just a fault, that will force it to reset. If the thing is truly broken, then you'll know.
Make sure the mag is out when you do it.
Old 05-16-2004, 05:28 PM   #8 (permalink)
WOT in Reverse
jllphan's Avatar
Prez gives good advice, i would have offered it earlier, but figured you had already tried this.
It could be a laser issue, but not deffinately. I would hate to spend the money to retool your changer with one of these kits only to find out it was something else. the only way to determine that this is deffinately the problem would be to take of the case, and watch what happens.
If the cd loads and turns, then it may be a laser issue (still says no disk but the laser isnt able to read the TOC and therfore doesnt recognize there is a CD in the drive).
If the disc wont even spin up, it could be the motor that turns the disc. this I would imagine would be replaced in this kit that rogue speaks of, but that would be a good question for him.
If neither is the case, there could be literally 20 other reasons why your getting that message.
Old 05-16-2004, 07:00 PM   #9 (permalink)
Car: 2008 128i
does it load the disc to be played or attempt to?
that could indicate problems with the loader mechanism or magainze.
2008 128i Jetblack
Old 05-17-2004, 12:28 AM   #10 (permalink)
hahaha. not really. you still stay on the subject huh. i fill my tanks up every sunday which lasts me through the whole week.
btw, i think it is the changer as a whole. bc the cd wont even load from the magazine.
im taking it to the dealer for them to it. (under warranty still)
ill post the problem later, thanks guys.
roguesniper-stop playing video games and put a real rifle in your hand
Old 05-20-2004, 11:51 PM   #11 (permalink)
Hey what did the dealership say about your changer?
Old 05-21-2004, 01:24 AM   #12 (permalink)
frank3 is an unknown quantity at this point
Time out! Before you spend a slug of dough, or you take a lot of things apart...try the "old standby"...it's worked for me and it's worked for many others.
With the cartridge in the changer, simply bang on the changer with your hand 2-3 times. I'm not kidding!! It can really work. Must move something around, or re-align something.
I read about this on another board a few months ago. I tried it and it worked. I've had no problems since.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Connecting Ipod to Factory Cassete/Disc Changer BMWfiend 3-Series (E36) 12 10-18-2005 03:25 PM
6 Disc Factory Cd Changer From '94 E36 bmwfanatice36 Audio/Miscellaneous Auto Parts 4 06-21-2005 10:18 PM
Need help ASAP. 318i factory HU and CD changer thekid Audio and Electronics 11 03-17-2004 10:39 PM
Factory CD Changer, will this fit? WickedBimmer 3-Series (E36) 2 02-04-2004 03:47 PM
