Easiest way to fit a amp/sub? - BMW Forum - BimmerWerkz.com
Old 12-22-2006, 04:39 AM   #1 (permalink)
RichM is an unknown quantity at this point
Hi there,
I have got an amp/sub set for Xmas, and I thought it'd be best to ask for advice with regards to fitting it. I'd prefer to avoid having to do any drilling. Does anyone know the best route to take the cables from the front to the back?
I have a 1995 E36. (Right-hand drive)
Thanks.
RichM is offline   Reply With Quote
Old 12-22-2006, 04:58 AM   #2 (permalink)
da_administrator
da_bull's Avatar
You should be able to put the main power wire through a grommet in the firewall. Make SURE you put the main power fuse as close to the battery as possible. This will protect your car if something should pinch or cut the wire. If you have an aftermarket stereo, run the remote turn-on wire and the RCA wires from the headunit to the rear. You should be able to snake the wires under the door sill plate and carpet to the rear. You may have to remove the back seat to get the wires in the trunk to your amp. When grounding, make your own ground, dont use any factory grounding spots. Scrape some paint away, use a ring terminal, and either screw or bolt the ring terminal to the scraped area. Hope that helps...
what size wheels fit? WarNox 3-Series (E36) 4 08-04-2006 12:22 AM
OEM M3 RIMS...FIT 325xi???????? NoBa 3-Series (E46, E90) 16 07-13-2006 04:15 PM
e30 m3 springs fit 89 325ic? xalier 3-Series (E21, E30) 3 04-05-2006 01:13 PM
can i fit 3.2 euro m3 engine in a 85 325e italianant02 3-Series (E36) 4 03-11-2006 09:42 PM
will these wheels fit ? azza_beemer 3-Series (E46, E90) 2 11-16-2005 09:38 PM
