E39 (1999) Radio Problem, Please Help - BMW Forum - BimmerWerkz.com
Old 01-15-2005, 03:56 AM   #1 (permalink)
Car: E60
anandvardhan is an unknown quantity at this point
I have an E39 from 1999 (UK model) with Professional audio system which includes a 6 CD changer and an amp in the boot. My audio system is stuck on a rather high volume and won't adjust from the vol knob or steering controls. Also, the tone cannot be adjusted and fader and left/right speaker selector are gone. However, the radio reception, casette and the CD changer are working fine. I got another head unit (from a 1998 528i) which plugs in fine and works but the same problem persists. My dealer won't tell me where the problem is but will change the whole system at the cost of an arm and a leg (and take the old system as well!).
I have been advised aftermarket systems but am not sure if I like the way most of them look.
Has anyone experienced a similar problem and what's the best way out?
Anand
anandvardhan is offline   Reply With Quote
Old 01-15-2005, 09:18 PM   #2 (permalink)
WOT in Reverse
jllphan's Avatar
If you have replaced your deck, by process of elimination, it's obviously your amp.
The head unit works as merely a preamp, and you have a remotely located amp in the "boot". Replace that, and your probably fine.
Weird though, I would think it would be the volume potentiometer.
Old 01-16-2005, 02:51 AM   #3 (permalink)
Car: E60
[snapback]272313[/snapback]
Thanks for that lead. Will give it a go.
I just had another thought. There is no way for me to know if the other head unit that I got from e-bay doesn't have the same problem as mine. Now what are the chances of that?
Anand
Old 01-16-2005, 09:31 AM   #4 (permalink)
WOT in Reverse
jllphan's Avatar
Astronomical
1999 E46 (328i sedan) and the radio will not work. abalto 3-Series (E46, E90) 1 08-04-2004 10:57 PM
E36 radio problem rwitt Audio and Electronics 23 07-01-2004 12:14 PM
E39 1999 528i Speedometer problem vinny 5-Series (E12,E28, E34, E39, E60) 4 06-24-2004 12:30 PM
1995 740il Radio Problem Pe!pe! 1,6,7,8 - Series and Mini Cooper 0 06-01-2004 11:38 PM
Problem with AM Radio otamara67 3-Series (E46, E90) 1 03-09-2004 11:15 AM
