| kick panel (floor) instructions are in my sig.
The tweeters in the door require you to remove the door panel. This is done by prying off the little clips behind the hand-grab thing (not the handle) and sliding off the trim around then handle. Behind the clips are torx screws. Unscrew those, then us a screwdriver, starting at the bottom, and use it pry the door panel loose. Plastic clips are all that hold it in place.
2000 MR-S Roadster= Current</span></span> |
