| take the blue wire (ant remote) off the harness, and hook up the blue/white wire from your radio. the blue wire is antenna only. it only has voltage when the tuner is playing and "lowering" your antenna, hence shutting your amp off. the blue/white off your radio is the amp lead, which stays hot, regardless of the source being played. Hope that helps...
da_male_cow
__________________  -There are 10 kinds of people. Those who understand binary, and those who do not.
-If we ever forget that we are One Nation Under God, then we will be a nation gone under...Ronald Reagan |
