car stereo in house? - BMW Forum - BimmerWerkz.com
Old 02-02-2004, 06:34 PM   #1 (permalink)
ssstorm7 is an unknown quantity at this point
Send a message via AIM to ssstorm7
how would i go about hooking car subs and amp (2 10" jlw0s and jl 250/1 amp) to my home stereo? i know i need a car battery or is there some way to hook the amp directly to the wall?
<a href='http://www.sounddomain.com/id/storm7' target='_blank'><img src='http://stormrares.hypermart.net/sigs/sig1.jpg' border='0' alt='user posted image' /></a>
ssstorm7 is offline   Reply With Quote
Old 02-02-2004, 06:41 PM   #2 (permalink)
2004BMW325Ci is an unknown quantity at this point
Just hook it up the same way you would inna car....
Except for power source.. you would need a ac/dc converter
Right?
To go from 110V to 12V
Or use a 12Volt battery just hook up a charger to it?
Be careful of the toxic fumes though, that emit when your charging...
Question..... WHY???
2004BMW325Ci is offline   Reply With Quote
Old 02-02-2004, 06:51 PM   #3 (permalink)
i have my old system sitting in my garage and theres nothin better than some boom in my room haha. if i got a converter would i still have to worry about the fumes?
Old 02-02-2004, 10:43 PM   #4 (permalink)
Defector
El Presidente's Avatar
You could plug the amp directly into the wall as long as you had a 12V DC converter, thus eliminating the battery need.
Old 02-02-2004, 10:52 PM   #5 (permalink)
Threadkiller
bitcore's Avatar
Ever dealt with computer power supplies?
Some assembly required, but it'd save you money if your serious about doing this.
Pick up a few power supplies (say, a couple 450W) and wire the 12v rails (the yellow wires) to the amp. Turn the supplies on and there ya go. You can look up how to hotwire an ATX power supply to turn on without a motherboard, it's easy.
Depending on the amp's class, you probably need at LEAST 200W over what the amp produces. You most definately want to put a cap in the circuit to ease the load on the supplies if you intend on doing this for a long time. Don't cheep out and try to get away with using less power supply power than you need. You could kill the ones you cheeped out with, costing you even more money.
This isn't a cheep project by the way, good supplys that actually put out 400+W run for about 40$
If you have a class A or AB amp, you are going to need a lot of juice to run it correctly as those are some of the least efficent amps out there.
Power supplys = no fumes
Sealed lead acid battery = no fumes, it's sealed.
Capaciter = no fumes, sealed
Wall current (in US) = 120V 60hz AC
Car battery = 12.2V DC
If you want more detail, I can describe the steps in detail of what to do to wire it up.
Old 02-03-2004, 05:10 PM   #6 (permalink)
Yes, use a computer powersupply, however dont expect it last too long. Ive had that setup for a while with 2 JL 12's and a 600w amp.
Just jumper the turn on (green) to a ground on an ATX power supply and run a wire from yellow to +12v, a short wire from +12 to remote and a wire from ground to ground.
easy deal. the amp will enver be able to put out the same kind of power that it can in a car though. I think a 450 w power supply is capable of at max 20 amps and you raverage sub amp consumes a minimum of 35. i can go into detail about how many amps it will draw and at what voltage if you told me how much power it puts out and at what ohm load you plan on running the speakers.
good luck
Old 03-09-2004, 12:40 PM   #7 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
Just get an AC/DC converter, hook the amp to the converter, plug the converter into the wall, and turn the radio on. No need to jumper anything, or risk frying something. You can get the converter at Radio Shack.
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 03-09-2004, 03:49 PM   #8 (permalink)
Threadkiller
bitcore's Avatar
You need multiple computer power supplys for this to work correctly. Wire the 12V and ground rails in parallel. Grab a couple 500 watter's and a riding lawnmower battery (or better yet a capacitor) to stick in-line and you will be alright.
Old 03-18-2004, 01:49 AM   #9 (permalink)
AdigA is an unknown quantity at this point
iam with bitcore computer power supplies are the best for such these things ...
E21 RuleZ
AdigA is offline   Reply With Quote
97 328i Stereo Installation gone awry AprilandTom Audio and Electronics 10 05-13-2009 12:18 PM
Me on my car, on the Freeway! 325eXTATIC Picture Showroom 20 01-19-2006 10:49 AM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
