Capasitor - BMW Forum - BimmerWerkz.com
Old 02-28-2004, 06:52 PM   #1 (permalink)
Mattitjah's Avatar
Mattitjah is an unknown quantity at this point
Send a message via MSN to Mattitjah
Any one know? Any diagrams? I got a 2ch Amp and two subs. Do I need two capasitors? Where do I wire them in?
Mattitjah is offline   Reply With Quote
Old 02-28-2004, 07:47 PM   #2 (permalink)
Threadkiller
bitcore's Avatar
depends on the wattage the amplifier consumes. The general rule is 0.1 farads per 100 W RMS the amplifier is rated for.
To install the cap, you charge it first, then you wire it in-line with the power cable to the amplifier.
It's best if you use one capaciter per amp instead of multiple ones per amp.
Caps come in different sizes. The more farads you have, the more power it's able to push out. If you have a 1,000W amp, you should get a 1 farad capacitor or larger.
Old 02-29-2004, 12:50 AM   #3 (permalink)
Defector
El Presidente's Avatar
I took this pic to show one member where the CD power unit comes from, but you can also see the cap wires in the background.
Basically, the cap has 2 prongs, a + and a -. You connect a ground to the - and run it to the same spot as your amp. On the + terminal, you connect two wires, one from the battery and another to the amp. You can see the red wire coming from the battery and the other red one going to the amp. You also want to mount it within 18 inches of the amp if at all possible.
Old 02-29-2004, 02:28 PM   #4 (permalink)
Mattitjah's Avatar
OK, I have a hard time making heads or tails of your pic. but you explanation makes sence.
So, pos. from bat. to pos. terminal on cap, then on to pos. suply on amp. Neg. terminal on cap has common ground with amp. Correct? All within 18" of amp(why?).
And I only need one cap since I only got one amp.?
Old 02-29-2004, 02:33 PM   #5 (permalink)
Calcartman is an unknown quantity at this point
Send a message via AIM to Calcartman Send a message via MSN to Calcartman
The negative terminal of the amp is supposed to be less than 18 inches because:
1. the longer the wire, the larger the voltage drop. Lower voltage means less power to the amplifier.
2. There is no reason not too. The ground can be to almost any metal thing in the car.
Liberalism: The haunting fear that someone, somewhere can take care of themselves.
Calcartman is offline   Reply With Quote
Old 02-29-2004, 06:22 PM   #6 (permalink)
ex owner/admin
Furious's Avatar
this is what it looks like on my car. its a rough diagram using MS paint.
Old 02-29-2004, 10:20 PM   #7 (permalink)
Defector
Any install sheet Ive ever seen clearly states to install the ground at the same point as the amp.
As for that pic, the red wire under the speaker goes to my amp. If you look in the background you can see another red wire and gray wire. Those go to the battery and ground. Ignore the smaller pic in the large one, thats for the CD changer.
Old 02-29-2004, 10:23 PM   #8 (permalink)
Defector
Mark, you have the cap's ground installed on the same line as the amp?
Old 02-29-2004, 11:21 PM   #9 (permalink)
ex owner/admin
Furious's Avatar
actually yeah it is, the shop said it will be ok and also beef up the ground to the amp or something like that. but i do know what your saying.
everything is in close proximity anyways so im not worried aobut distance.
Old 03-01-2004, 05:39 PM   #10 (permalink)
Mattitjah's Avatar
Found THIS .
It's the same as what Furious posted.
Old 03-01-2004, 05:41 PM   #11 (permalink)
Mattitjah's Avatar
Damn link won't work.
This is the link:
http://www.lightningaudio.com/scripts/late...ed=001001454788
Old 03-01-2004, 05:42 PM   #12 (permalink)
Mattitjah's Avatar
@#^$%&@#$^#$^@^%AAAAAAAAAARGH!!!
(sorry)
Old 03-01-2004, 05:47 PM   #13 (permalink)
ex owner/admin
Furious's Avatar
no worries.
here is what you were looking at, yeah its similar to what i have set up
