Brake light fault - BMW Forum - BimmerWerkz.com
Old 11-03-2008, 07:28 PM   #1 (permalink)
PrInG's Avatar
Car: 95 Dakar Yellow M3, 00 1.8T VW GTI
PrInG has a spectacular aura aboutPrInG has a spectacular aura about
Send a message via AIM to PrInG
Brake light fault
Hey I was just wondering, I've been having some problems keeping my brake lights on seems like there is a bad connection. Every once in a while I have to get out and fool with the sockets. And when I get the back two to work the computer tells me problem with brake light circuit.. Where is a good place to look to get that third brake light up and workin ?
TO HONOR: Get Honor Stay Honor if You Can't Come in Her Come Honor.
"its not banana yellow but its not golden its just that perfect creamy german goodness"
- Bow
PrInG is offline   Reply With Quote
Old 11-03-2008, 09:28 PM   #2 (permalink)
Have you looked at it from in the trunk?
Old 11-03-2008, 11:08 PM   #3 (permalink)
PrInG's Avatar
yea I assume there is a bad wire somewhere but I'm not sure where to look.. I was hoping there was a common place that shit went wrong. maybe that isn't the case ?
- Bow
Old 11-03-2008, 11:15 PM   #4 (permalink)
Have you tried a multimeter on the socket itself?
Old 11-03-2008, 11:50 PM   #5 (permalink)
PrInG's Avatar
i don't have a multimeter up in toledo.
- Bow
Old 11-04-2008, 06:28 AM   #6 (permalink)
da_administrator
da_bull's Avatar
Sometimes the sockets go bad. Also, make sure the correct bulb is in there. Look at your manual. Some will fit in the socket and work on occasion but not the right one.
Old 11-05-2008, 10:23 AM   #7 (permalink)
PrInG's Avatar
sorry man, I'm lucky I got door panels with this car let along a manual. haha.. I had replaced the passenger side brake light w a bulb and socket that def. weren't the right ones. They however worked, but the p.s light was very dim when I pressed the brake.. I just tried switching it out for what Ithought was the right one and it didn't work .. any ideas..
- Bow
Old 11-05-2008, 10:53 AM   #8 (permalink)
If the bulb is a 2 part, one for the parking light and one for the brake, it may just have been in backwards. If so, turning on the parking light would light up the brake light part of the bulb in a 2 part taillight. But the E36, like many BMWs, have separate brake and parking lights; so a one part bulb with brake only and another with parking only should be fitted to separate taillights. (This means that the parking light test wouldn't work.)
Old 11-05-2008, 04:59 PM   #9 (permalink)
PrInG's Avatar
its a 1 part bulb..
- Bow
Old 11-05-2008, 05:15 PM   #10 (permalink)
I guess it's gotta be the wrong bulb or a bad socket.
Old 11-06-2008, 12:36 AM   #11 (permalink)
PrInG's Avatar
ill attempt to fool with it tomorrow hopefully I can get something to work properly = ) thanks fellas I'll let you know if it works if not.. back to the drawing boards
- Bow
Old 11-08-2008, 03:32 PM   #12 (permalink)
PrInG's Avatar
ok got the two main brake lights working properly.. Still says to check brake circuit and there is still one out.. That being the one in the rear windshield... Any ideas? I have a socket which I would guess is the right one.. The pins come off at like 120 degress from eachother as opposed to the other brake lights where the pins are 180 of eachother.. Where is a good spot to check for the bad circuit ?
- Bow
Old 11-08-2008, 06:33 PM   #13 (permalink)
Any reason the actual wires could have been cut?
ABS light, brake light and TCS offline on 528i... ideas? rmory 5-Series (E12,E28, E34, E39, E60) 5 08-14-2008 10:01 AM
ABS Light on But no Fault Codes (92 325is) R_F_L 3-Series (E36) 6 05-31-2007 08:32 AM
92 e36 fault codes? check engine light seven 3-Series (E36) 1 11-15-2006 03:50 PM
HELP, e36 brake light curcuit fault code theogill 3-Series (E36) 4 08-27-2004 07:48 AM
ABS sensor light fault.. Ski Bimmer Talk/Motorsports Talk 6 04-18-2003 08:38 PM
