Barrel Connectors - BMW Forum - BimmerWerkz.com
Old 06-08-2004, 03:45 PM   #1 (permalink)
peffman is an unknown quantity at this point
I'm embarassed to ask this, but I just wanted to be sure before I start. When using barrel connectors, do the two wires need to overlap before you crimp them together, or is the barrel connector a sufficient enough conductor where they don't have to overlap. I would overlap them just to be sure, but I think the diameter of the connectors I bought might not be big enough. Thanks for anyone's help.
peffman is offline   Reply With Quote
Old 06-08-2004, 03:47 PM   #2 (permalink)
Defector
El Presidente's Avatar
im not familar with a barrel connector, are you sure you don't mean butt connector? The part I am speaking of is a round tube open at both ends.
If that is the part, the more solid the connection, the better.
Old 06-08-2004, 05:09 PM   #3 (permalink)
Yes, you're right, they are butt connectors. I guess I'll just have to exchange them for a bigger size. Thanks.
Old 06-08-2004, 06:55 PM   #4 (permalink)
WOT in Reverse
jllphan's Avatar
18-22AGU should work fine, and no they don't have to overlap, the metal on the inside of the barrel (I refuse to say "inside the butt") will transfer the flow of electricity just fine.
Old 06-08-2004, 11:51 PM   #5 (permalink)
Defector
LOL.
Old 06-09-2004, 09:51 AM   #6 (permalink)
Car: 2008 128i
he said "inside the butt"
2008 128i Jetblack
Old 06-09-2004, 11:52 AM   #7 (permalink)
WOT in Reverse
jllphan's Avatar
Now your just putting words in my mouth...
Old 06-09-2004, 12:08 PM   #8 (permalink)
Car: 2008 128i
nope you said it. I was just having fun.
2008 128i Jetblack
Old 06-09-2004, 12:16 PM   #9 (permalink)
ex owner/admin
Furious's Avatar
a lot of people actually twist the wires before using a barrel connector, but i wouldnt only because sometimes you might break the wire when it twists and cause you headaches when you dont realize its broken, ususally (and i dont personally use these because working for a telecomunications company i have the best connectors 3M make) i just overlap them a few times.
Old 06-09-2004, 01:10 PM   #10 (permalink)
Car: 2008 128i
I think you are thinking of the tiwst on connectors. the butt connectors get crimpted on the wires.
2008 128i Jetblack
Old 06-10-2004, 09:35 AM   #11 (permalink)
TWKTCC is an unknown quantity at this point
Butt connectors are ok, bell caps are ok too, nothing beats solder and tape/ heat shrink though!
TWKTCC is offline   Reply With Quote
My 540i Vs. Construction Barrel ///Matt 5-Series (E12,E28, E34, E39, E60) 10 08-20-2005 05:44 PM
Ignition Barrel Replacement markyd 3-Series (E36) 3 07-07-2005 04:30 PM
Plastic Connectors 85-325e 3-Series (E21, E30) 1 03-16-2005 05:19 PM
Lock barrel removal jimos123 3-Series (E36) 2 03-23-2004 01:52 PM
Radio Connectors (Plugs) Rainman66 3-Series (E21, E30) 11 08-07-2003 10:39 PM
