antenna - BMW Forum - BimmerWerkz.com
Old 03-16-2004, 01:27 PM   #1 (permalink)
socalguy is an unknown quantity at this point
My radio is coming in with static... i pretty
much dont get any stations, it sucks i was wondering
if anyone knew where the antenna was so i can
check it out. Make sure its hooked up. or why i wouldnt
be getting stations?
socalguy is offline   Reply With Quote
Old 03-16-2004, 05:59 PM   #2 (permalink)
Car: 2008 128i
Many have it as part of the rear window defrost grid.
2008 128i Jetblack
Old 03-16-2004, 06:11 PM   #3 (permalink)
schneider252's Avatar
if you have an old school one like mine then it comes up in the back...Every time you turn the radio on the antenna goes up, turn it off and it goes down
Soo, if you have that kind of antenna maby its broke, if its build in the windshild them its prob just a bad antenna, window antennas are known to get bad reseption ghead
Old 03-16-2004, 07:02 PM   #4 (permalink)
Car: 2008 128i
Mine works great.
When you do use your rear defroster does it not work real well or leave areas not defrosted? if so then you may try repairing that with a kit from your local auto-parts store and thus fixing the defrosting and antenna at the same time.
2008 128i Jetblack
Old 03-18-2004, 02:02 PM   #5 (permalink)
the defroster works great, its a 96 328is
but for some reason the radio stations wont come in
maybe i have to take it out and check the back of the
head unit??...
Old 03-18-2004, 02:50 PM   #6 (permalink)
Defector
El Presidente's Avatar
check the actual connection at the antenna. It is my understanding the e36 actually has 3 and the receiver pulls the best signal from that one. The main antenna unit is located under the trim on the rear drivers side pillar. Its possible over time the connections have come loose.
Old 03-19-2004, 01:24 AM   #7 (permalink)
hopefully that is what it is, i will check it out tomorrow
thanks.
cellular phone antenna. fbmcross 3-Series (E36) 1 09-11-2005 06:43 PM
Shark Fin Antenna DexBeemer 3-Series (E46, E90) 0 04-07-2005 05:00 PM
Antenna For '90 325i sweetlilbug Classifieds Sell & Buy 0 02-23-2005 07:23 PM
Where is the antenna located on my 89 525i? TylerJ 5-Series (E12,E28, E34, E39, E60) 1 05-03-2004 11:00 PM
Cell phone antenna wire run andradef 5-Series (E12,E28, E34, E39, E60) 0 02-01-2004 02:52 PM
