is this amp good enough? - BMW Forum - BimmerWerkz.com
Old 11-06-2006, 01:25 AM   #1 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
MiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond repute
Send a message via AIM to MiguelACA
i need an amp to power two 10'' kicker comps
these are the specs on the subs:
» 10" 4-ohm subwoofer
» polymineral cone with double-stitched foam surround
» high-strength steel basket
» frequency response: 30-500
» power handling: 50-150 watts RMS
» peak power: 300 watts
» sensitivity: 87.3 dB
» mounting depth: 4-13/16"
» spring-loaded nickel-plated terminals
» sealed box volume 1.0-2.4 cu. ft.
» ported box volume 1.25-1.75
» works in free-air applications
would this be a good choice to power them?
eBay: FACTORY TESTED BAZOOKA BA1500 500 WATT MONO SUBWOOF AM (item 220044394905 end time Nov-08-06 09:45:45 PST)
the subs will be bridged since the box only has one thingy (lol) to connect both subs
any other suggestions as to what amp to use?
this is the amp that my cousin is using to power these exact subs, and it sounds awesome, just wondering if there is something better i could use?
eBay Motors: DEI XTREME XA-5001 500 WATT MONO BLOCK AMPLIFIER (item 290034926218 end time Nov-28-06 10:54:03 PST)
A morning of awkwardness is better than a night of loneliness
MiguelACA is offline   Reply With Quote
Old 11-06-2006, 05:06 AM   #2 (permalink)
da_administrator
da_bull's Avatar
A good rule of thumb, is look at the fuses. The Extreme has 2-30amp fuses, or 60 amps. R-O-T: take the fuse rating, multiply it by 6, that'll give you the power it actually does. So 60x6=360. 360 is the actually RMS power that it will do. D-class amps you can multiply time 9, since they are more efficient. So in the case of the Bazooka, it has 3-20amp fuses, so it should do the same power.
There is a big, long formula for figuring out actual power, but that will get you close enough.
You see how your subs have an RMS power and peak power. Throw the peak/max power in the trash on anything mobile audio, because it is a made up number by the manufacturer. Concentrate only on RMS power ratings, that's what matters. Max/peak power usually is twice what the RMS power is (or close).
I have installed both amps, and there is a reason that the Xtreme one is more, its a slightly better amp.
Ok, my fingers hurt from typing , gotta go to work, hope that helps...
Keep the shiny side up...
Old 11-06-2006, 10:51 AM   #3 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
hmm, i think i understood what youre telling me, so then i guess i should go for the xtreme amp then, is there anything else along the same price range, or do you recommend that i jsut go wth the xtreme amp???
Old 11-06-2006, 06:00 PM   #4 (permalink)
da_administrator
da_bull's Avatar
Not really, thats pretty cheap, for what you are getting. Just make sure that if you get anything electronic on ebay you make sure its from a reputable seller and ask about a warranty.
Old 11-06-2006, 06:30 PM   #5 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
i was gonna get the bazooka amp on ebay, the price was nice and 2 year insurance on it is 8 bucks, but since u think that the extreme amp would be better, im gonna buy it locally, its like 89.99 here
Old 11-06-2006, 08:50 PM   #6 (permalink)
da_administrator
da_bull's Avatar
Kewl, I always prefer electronics from a brick-and-mortar store, just for the fact you can chew on someone if it goes wrong. Its worth the extra little bit just for that fact.
Old 11-07-2006, 12:16 AM   #7 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
yea, i do too, just that square trade offered 2 year insurance on the amp for 8 bucks, still, ill get the xtreme amp
thanks alot, really appreciate it!
Old 11-07-2006, 05:01 AM   #8 (permalink)
da_administrator
da_bull's Avatar
No problem, have fun...
Aftermarket amp to stock head unit problem Hurdle Audio and Electronics 7 04-23-2006 06:13 PM
Good upgrade Bethlehem Motors 3-Series (E36) 14 03-20-2006 08:27 AM
is my 2 channel amp good or will i need a 4 channel B3M2W5i Audio and Electronics 22 02-02-2006 10:06 AM
To all BMW gurus . . . is this a good deal? bdonkersgoed 5-Series (E12,E28, E34, E39, E60) 10 05-29-2004 12:48 PM
