AMP emergency - BMW Forum - BimmerWerkz.com
Old 08-21-2004, 01:40 AM   #1 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
wats the deal? i have 8 new speakers for my e36 and 2 new 10's....can i get a sub that will power everything or will i need 2 seprate??? PLease respond soon i wana get my sounds up and running...
Old 08-21-2004, 02:09 AM   #2 (permalink)
Defector
El Presidente's Avatar
If you buy a 2ohm stable 5ch amp you can power them all off one.
Old 08-21-2004, 02:35 AM   #3 (permalink)
Slvr e39's Avatar
Car: Dinan Stg 1 M3
Slvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond repute
Send a message via AIM to Slvr e39
Or you could just bye two amps, and make a sick dual amp rack
Dinan Stg 2 Phoenix Yellow M3
Slvr e39 is offline   Reply With Quote
Old 08-21-2004, 09:20 AM   #4 (permalink)
Power Shifting
Cruzin 323is's Avatar
i would go for 2 different amps...
-SOLD..
R.I.P Fast 6
Old 08-24-2004, 11:59 PM   #5 (permalink)
General Chaos
Car: ///M3,Corolla
how much wattage on each amp? i have 2 10's that are 1100 watt each and lets jus say the speakers are all stock, what are watts and ohms i need on both?
Old 08-25-2004, 01:20 AM   #6 (permalink)
Defector
1100 peak or RMS.
Check your RMS rating, thats where the power needs to be. With stock speakers its not even worth amping them.
Old 08-30-2004, 02:29 PM   #7 (permalink)
mlomker is an unknown quantity at this point
Send a message via Yahoo to mlomker
If they are stock speakers then you'll probably blow them if you use much of an amp on them at all--I've read quite a few posts about guys who went aftermarket amp and popped the stock speakers within days.
1100 watt sounds high for a 10" sub. I was looking at CDT's specs for my new system and it's 400 watts RMS/800 watts peak for a 12" DVC sub from them.
My last system powered a sealed 12 with 300 watts. Once you cross 5-600 watts or so (for the entire system) you need to start thinking about your battery, capacitors, and alternator because they might not be able to supply the juice even if your amps are capable of taking it.
mlomker is offline   Reply With Quote
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
For sale 12" Apline Speaker and 1400 Watt Amp scottm3 Audio/Miscellaneous Auto Parts 4 03-31-2006 09:53 PM
AMP Power cable! 316i e36 94 Butterfingers Audio and Electronics 1 10-09-2005 08:44 PM
How do you install amp and subs to a stock headunit? t5sesco Audio and Electronics 2 09-16-2005 01:26 AM
Emergency HELP PLZ MY CLUTCH PED. BmWNoobie 3-Series (E21, E30) 4 10-13-2003 02:12 AM
