Alpine 9835 Fm Tuner Problem - BMW Forum - BimmerWerkz.com
Old 09-22-2004, 02:08 AM   #1 (permalink)
ultraviolet353 is an unknown quantity at this point
Ok so I chose not to install it myself and went another route when presented with a good deal from a professional installer...I just got a new system installed today. Alpine 9835 head unit (HU). MB Quart Reference 5.25" Components, JL Audio 4300 4 Channel Amp, and JL Audio 10" sub. It sounds unbelievable. The head unit is ridiculous! I love it (amber mode matches BBimmer spot on). One weird problem...the FM reception (haven't tried the AM recep yet). I live in Los Angeles, and have previously owned low-end Sony HU's and never had any problem tuning my favorite stations on two different cars (everything always came in clear, no intereference). This unit is different: when set to auto DX tuning, it only tunes 4 stations, the rest have to be done manually (and even when tuned manually I get continual hits of of intereference)...weird, huh. In local mode, it doesn't tune any stations automatically. Every station I listen to must be tuned manually (which I never I had to do before with my $100 Sony CD HU's). I had it professioanlly installed at my local Al & Ed's. I am going in tomorrow to let them know the problem, but I want to be armed with a little bit of knowledge. First, is it possible that the HU's antenna is faulty? or possibly something else in the HU that could be damaged that is causing poor reception? or is it an installation problem in that perhaps the antenna is rubbing against something that is causing interference? or that the antenna is not properly installed? Any other ideas that could be causing this problem? Last point: the HU has a setting that has "Stable, Normal, and Hi-Fi." The manual says that if you are not getting desired reception at Hi-Fi (best quality setting) try "normal" and "stable." I have tried all settings to no avail. Any ideas would be greatly appreciated.
ultraviolet353 is offline   Reply With Quote
Old 09-22-2004, 11:18 AM   #2 (permalink)
Defector
El Presidente's Avatar
The HU has little bearing on FM reception. The problem is the car. I have been told e36 uses 3 antennas, from which the factory HU selects the strongest signal automatically. With an aftermarket HU, two cut out and the only one that functions is the one imbedded in the rear glass. There is a fix, and it invloves a blue wire going to something. I'll look later.
Old 09-22-2004, 12:13 PM   #3 (permalink)
MrChance's Avatar
MrChance is an unknown quantity at this point
Send a message via ICQ to MrChance Send a message via AIM to MrChance Send a message via MSN to MrChance
I did some research on this- its that the factory antenna has a line amp in it, and with an aftermarket head there is no power supplied to that amp.
There is a fix where you can run your own power wire from the blue wire hookup on the factory speaker amp in the trunk to the antenna amp mounted on the C pillar (I think its C).
There is a how-to on some BMW site somewhere, but I am having a hard time finding it. I am going to attempt to do the procedure this weekend, if I get it without burning my car down I will post it up.
Three Words: More Cow Bell
Member of the &quot;My last BMW had 462k miles on it and still ran like a monster so I bought another one&quot; club.
MrChance is offline   Reply With Quote
Old 09-22-2004, 01:17 PM   #4 (permalink)
But here's the thing: This Alpine HU replaced another after market HU (Sony CDX-C5000X) and it had crystal clear reception on this very same E36????? I am going to take it into the installer and see what he thinks--I will propse the suggestion you guys had. Thank you.
Old 09-22-2004, 02:31 PM   #5 (permalink)
Defector
Its very possible the installer didnt hook up the blue wire right.
Old 09-22-2004, 02:32 PM   #6 (permalink)
Defector
Then again, I say forget it all together.
Beyond AM
Beyond FM
XM.
Serious sound improvement.
Old 09-22-2004, 10:39 PM   #7 (permalink)
...just checked the AM signal, and I am not getting any stations. Pres--what is the proper way to hook up the blue wire?
Old 09-22-2004, 11:09 PM   #8 (permalink)
Defector
Not sure without looking, but I dont have time. If I recall, connect it to the blue/white wire.
528i Alarm Problem Xero 5-Series (E12,E28, E34, E39, E60) 5 01-03-2011 01:16 PM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
Cd Changer Adapability nookatee Audio and Electronics 5 02-05-2005 11:36 PM
FS: Alpine IVA-C800 Mobile Multimedia Station ACS_Nick Classifieds Sell & Buy 1 04-19-2004 01:10 AM
