Alpine 9831 into '98 328 coupe with HK? - BMW Forum - BimmerWerkz.com
Old 07-11-2004, 09:23 AM   #1 (permalink)
bobster's Avatar
bobster is an unknown quantity at this point
Hi All
Have a '98 328 with the HK setup. Looking to install an aftermarket HU and after reading around, seems like the favourite brands are alpine and nakamichi - people seem to rate these for SQ and also match with the dashboard.
my preference is for the alpine given its greater compatibility (mp3 cd etc).
tempted by the 9831 as doing the install myself and i understand that the higher spec models (9833 up) require a separate wire to the battery which sounds a bit complicated (probably v s'forward if u know what you're doing). also am guessing that the additional power of the amp in the 9833 won't benefit my anyway as i'll be running through the HK amp(?)
have the following qns if anyone can help:
-will the 9831 install be a simple as plugging in a harness adapter and radio adapter?
-will this cause any problems with the HK system?
-given the HK system has its own amp, would i be able to use the amps in the head unit to drive a sub-woofer i fit one at a later date?
-does anyone have any comments on the 9831 vs other models in the alpine range?
-i understand the 9831 buttons appear orange, but the text on the screen can also be changed to show orange. is this straightforward?
any thoughts much appreciated!
bobster is offline   Reply With Quote
Old 07-11-2004, 09:53 AM   #2 (permalink)
bobster's Avatar
ps - am guessing that a new head unit will give me improved sound qual vs the standard head unit?
am looking to swap the head unit rather than getting a new oem bmw boot changer which i'm guessing may not play mp3 cds and does not give me upgradeability down the line.
...but i quite like the stock look of my current h/u...
Old 07-11-2004, 11:22 AM   #3 (permalink)
WOT in Reverse
jllphan's Avatar
Your Alpine will come with a harness. You will also need to buy an aftermarket harness for your BMW (Metra part no. 70-8590). Both of these harnesses have bare wire on one end and a plug on the other. merely connect the bare wire ends, and you are left with a harness with plugs on each end. One goes to your car, the other to your new radio. Simple. This shouldn't cause any trouble to your existing system. You will also need an antenna adaptor for your new deck (Metra Part no. 40-NI10).
You don't need to run a seperate wire to the batttery. Alpine's V-drive internal amps are good, but that's a little overkill in my book. They also don't have enough juice or proper crossover to run a sub now or later.
The CDA-9831 by Alpine is a decent deck. But I thought the illumination was blue/green. And I wasn't aware that any of it could be switched permenently to amber.
Old 07-11-2004, 12:48 PM   #4 (permalink)
Defector
El Presidente's Avatar
The only Alpine model I know of that switches to amber is the 7894. I know their are others, but I don't know their models, as I haven't been shopping for a new one lately.
My 7894 is not connected to the battery, and it still draws ample power. Even without a sub in the car, it has sufficeint draw to dim the lights. Also, you are correct about power. The HU is sending a signal to the amp, and the amp is sending power to the speakers. You will still gain SQ, but not as much as if you were to bypass the amp.
Old 07-11-2004, 01:25 PM   #5 (permalink)
bobster's Avatar
thanks guys. wondering if the colour confusion is as i'm based in the uk and looking at a uk / euro spec alpine head unit - uk model is actually called 9831r and comes with 'i-personalise' which permits you to select one of 512 (i think) colours for the buttons.
http://www.alpine-europe.com/alpine/cms/de...p=277&details=1
in case you're wondering, cheapest prices i can get on a mail order euro spec unit are much higher than the deals you US guys can get from somewhere like crutchfield...
el presidente - saw the pics of your headunit in the sticky post at the top of the ice forum here - do you have any more pics which show more of the dashboard with the alpine h/u in place? just be interested to see how it looks vs a larger expanse of dashboard
Old 07-11-2004, 07:02 PM   #6 (permalink)
Defector
Don't think I do...I'll check. If not, I'll take some.
Old 07-11-2004, 07:57 PM   #7 (permalink)
Defector
from the backseat...
Old 07-12-2004, 03:46 AM   #8 (permalink)
bobster's Avatar
thanks man!
that looks good!
Fs: 1999 M Coupe All Original pkramer Classifieds Sell & Buy 0 11-04-2004 08:47 AM
Alpine Cda 9831 matt323is Audio and Electronics 1 10-06-2004 09:34 PM
alpine 9831 into HK system - power + setting qn bobster Audio and Electronics 1 07-19-2004 04:15 PM
Coupe De Grâce: 645Ci Stacy540i Bimmer Talk/Motorsports Talk 15 11-24-2003 06:56 AM
