Aftermarket HU to factory harness - BMW Forum - BimmerWerkz.com
Old 03-12-2004, 02:34 PM   #1 (permalink)
schverp is an unknown quantity at this point
96 328i (non Harmon Kardon):
I'm replacing the Bose head unit with a Nak CD400, which has 4v preamp outs, 47 watts (hi level outs), and a low THD rating.
I realize the best way to do this is to rewire all new spkrs with an aftermkt amp. For a rapidly upcoming roadtrip, however, i want to just plug it in to the factory harness and use existing factory amp and spkrs as a temp setup.
Problem is, i'm getting mis-information. I've been told method 1 is better than 2 and vice-versa:
1) Standard harness - uses hi level outs to factory amp.
2) Amplifier integration harness - similar to standard harness, but incorporates the preamp outs, which lowers the impedence and signal sent to the factory amp.
Any advise/suggestions on which would give the best sound and not cause any damage to my new baby.
Thanks, Craig
schverp is offline   Reply With Quote
Old 03-14-2004, 12:01 AM   #2 (permalink)
WOT in Reverse
jllphan's Avatar
I too faced a similar problem, upon buying my car I needed something IMMEDIATELY! So I threw in a Nak CD45-z and just used a metra harness (I think a 70-8590 Part no.) to interface the decks amp to the car's amp. It works fine, but I quickly installed a proper audio system now that I've had the time!
Old 03-15-2004, 02:23 PM   #3 (permalink)
good to know, thanks jllphan...
Installing Aftermarket Amp/sub In E34 Dr. Pipper Audio and Electronics 4 03-03-2009 07:43 AM
Factory Amp Aftermarket Subs Sisco360 3-Series (E46, E90) 0 04-12-2005 07:24 PM
Cd Changer Adapability nookatee Audio and Electronics 5 02-05-2005 11:36 PM
Another E39 aftermarket H/U install.....SOS! Endangered Beatz Audio and Electronics 6 05-31-2004 10:26 PM
adding aftermarket amp to factory head unit DHW BMW328I Audio and Electronics 15 05-27-2004 07:25 PM
