Aftermarket amp to stock head unit problem - BMW Forum - BimmerWerkz.com
Old 04-22-2006, 08:38 AM   #1 (permalink)
Hurdle is on a distinguished road
Angry Aftermarket amp to stock head unit problem
Ok so a while back I sis an aftermarket amp install in my car and used the instructions at http://forums.bimmerforums.com/forum...p/t-74181.html to use for the wiring part of it. Once everything was hooked up I noticed that if I had both rca jacks plugged into the amp then the sound coming from the sub was significantly less than if I only had one rca jack plugged in. I went back and check all the wires and they were all good so I don'tknow what's up. I can change which rca jack is plugged in and its the same thing. I've changed the line out converter (first was a Periperhal SVEN 4 and the current one Periperhal SVEN 2) and it's the same thing. Then I bought a new amp and still the same mess. Anybody else have this problem or know a remedy? Thanks...Chris
Hurdle is offline   Reply With Quote
Old 04-22-2006, 04:06 PM   #2 (permalink)
winters97E39's Avatar
Car: 1997 BMW 528i
winters97E39 is a jewel in the roughwinters97E39 is a jewel in the roughwinters97E39 is a jewel in the rough
Send a message via ICQ to winters97E39 Send a message via AIM to winters97E39
are you using a speaker level input to RCA converter, or going from the preamp output from the head unit direct to the RCA?
I used wire taps and spliced an RCA cable into the preamp outputs from my headunit on my e39. sounds excellent.. positive wire goes to the center wire on the RCA, negative to the outside wire.
Jason / 1997 528i
winters97E39 is offline   Reply With Quote
Old 04-22-2006, 04:16 PM   #3 (permalink)
I went preamp to converter at the factory amp.
Old 04-22-2006, 10:11 PM   #4 (permalink)
da_administrator
da_bull's Avatar
Either the speaker wire input to the converter is backwards, the converter is wired internally backwards, or the subs are wired backwards from each other. What you are hearing (or lack of as the case may be) is the subs out of phase with each other. One is moving in while the other is moving out, cancelling each others air movement. Real quick, swap + and - on only one sub, see if that fixes it. It should and your done...
Hope that helps...
Old 04-22-2006, 11:01 PM   #5 (permalink)
I only have one sub granted its dual coil, but the last sub I had was single voice coil and it did the same mess. I guess it may be switched around at the converter? Maybe the instuctions I used were wrong....
Old 04-23-2006, 12:53 AM   #6 (permalink)
Wonderboy's Avatar
Car: 98 M3 Sedan
Wonderboy is on a distinguished road
honestly it sonuds like a possible bad ground. check all of the ground wires and make sure they are attached very well...
Wonderboy is offline   Reply With Quote
Old 04-23-2006, 05:13 PM   #7 (permalink)
da_administrator
da_bull's Avatar
what flavor of converter are you using? it may be your factory wires are backwards, but it does sound like they are out of phase somewhere. Ive even seen speakers wired backwards (DVCs especially), Ive had speakers out of the box that the magnets had no magnetic properties, a bunch of silly things over the years. Since you had a SVC and it did the same thing, it leads me to believe one side of the converter or its wiring is labeled backwards from where the wires go internally. swap the speaker leads at the input of the converter on one side only.
Old 04-23-2006, 06:13 PM   #8 (permalink)
The converter is a Periperhal SVEN 2 which I've heard a lot of people recommend. I had a Periperhal SVEN 4 before that one and it did the same thing so I'm think it's not the converter but maybe the wires on the car. I went by the wire list that's on http://forums.bimmerforums.com/forum...p/t-74181.html I'll have to take a closer look at it when I get back home and try switching some of the wires around. Thanks for the suggestions!
Head Unit Install Complete On 1987 L6 Builder Audio and Electronics 1 01-27-2005 05:00 PM
Head Unit Reccomendations d3ity Audio and Electronics 3 05-11-2004 07:03 PM
FS Stock head unit and cd changer from 99 M3 bmwspeed Classifieds Sell & Buy 0 04-19-2004 04:53 PM
OEM Head Unit mmendell Audio and Electronics 6 04-16-2004 08:49 PM
Factory Head unit Keehnel1414 Audio and Electronics 9 02-26-2004 07:56 PM
