328is Audio Questions - BMW Forum - BimmerWerkz.com
Old 03-14-2004, 11:38 AM   #1 (permalink)
matt_nemesis is an unknown quantity at this point
I just purchased a 1996 328is and I am really happy with the car except for one thing, the stock audio system. I only have standard HU with the cassette and radio, but I want a CD player. Also I think that the left rear speaker is blown as it makes a strange vibrating sound when any music is played.
I want to add in a CD changer with a Soundgate Interface
and also replace the rear speakers.
For the CD changer I was thinking of going with the Kenwood
or the Sony
For the rear speakers I am not sure about size and brand although I have read that they should be 4in right?
I have also thought that maybe it is easier and cheaper to just put in a Aftermarket HU but do they fit in the center console? It seems as though the standard HU is bigger than a regular one?
I also have a pretty limited budget in regard to all of this.
Thanks
matt_nemesis is offline   Reply With Quote
Old 03-14-2004, 04:55 PM   #2 (permalink)
eloff19's Avatar
eloff19 is an unknown quantity at this point
Send a message via AIM to eloff19
an aftermarket head unit will work just fine; you'll need a wiring harness (crutchfield ~$20); rear speakers are 4" yet if you're up to the job you can make other sizes fit - i'd also look into changing the kick panels up front to some good components; and adding a sub
since you mention you're on a budget don't bother adding a handshake for a cd changer just buy a new h/u with one in it (just my opinion anyway)
eloff19 is offline   Reply With Quote
Old 03-14-2004, 05:30 PM   #3 (permalink)
WOT in Reverse
jllphan's Avatar
If your limited on budget, replace your factory deck. Adding a cd changer (after buying the adaptor) is more expensive and wouldn't sound as good as a new deck.
---Buy Kenwood or Pioneer (if on a budget); Alpine, Nakamichi, Clarion, or Eclipse if you can spend a little more.
Speakers= Infinity,or polk audio (5.25" replacement size)
As far as install goes, no you don't need a dash kit. The BMW factory head unit is standard single din size (same as aftermarket).
Old 03-14-2004, 05:33 PM   #4 (permalink)
WOT in Reverse
jllphan's Avatar
I hate it when someone posts while I'm typing a post!! LOL!
Just to avoid confusion, you should have 1" tweeter, 4" mid (both in door) and a 5.25" in the kick panel. I FEEL like it is more advantageous to disconnect the 4" all together and just get a 5.25" component set ( 5.25" mid and 1" tweet) if you asdd a new head unit
Old 03-14-2004, 06:48 PM   #5 (permalink)
eloff19's Avatar
haha i'm with you on that jllphan - there should be a feature of who's replying err somethin' weird like that (i don't know)
i post things and someone else posts seconds before me saying the same thing i did and it gets me sad
Old 03-15-2004, 09:07 AM   #6 (permalink)
Thanks for the advice guys, I have wanted to change out the HU from the beggining and put in a new aftermarket HU. The only problem is that even though it is my car, my dad doesn't want me to change anything on the center console, I don't understand his logic though.
So I won't need a dash install kit, just a wiring harness?
BTW, where is the kick panel? (excuse my noob questions)
Thanks very much guys, I really appreciate it.
Old 03-15-2004, 12:27 PM   #7 (permalink)
Defector
El Presidente's Avatar
you'll need a small trim ring to make it look better.
Old 03-15-2004, 05:43 PM   #8 (permalink)
Car: 2008 128i
alot of HUs do include that though. if it is the small piece that goes around the outside.
2008 128i Jetblack
Old 03-15-2004, 10:11 PM   #9 (permalink)
WOT in Reverse
jllphan's Avatar
The kick panel is the side panel underneath the dash, in front of the door (it is next to where your feet are). And every deck i have ever seen (or sold) comes with a trim ring that is large enough to cover the hole. Tell pops that (using an aftermarket wiring harnes) you can reinstall the factory deck with no drama when needs be.
1995 325i Audio Questions Bimmer-325i Audio and Electronics 2 09-09-2005 04:32 PM
few audio questions brien4787 Audio and Electronics 0 09-14-2004 09:59 PM
Bought '97 328is: Have questions CBD328is 3-Series (E36) 3 09-09-2004 07:09 AM
audio nav setup questions h00d Audio and Electronics 1 07-04-2004 10:04 PM
Bought 1998 328is... some questions ExoDemon 3-Series (E36) 5 11-22-2003 03:50 PM
