| I messed around with a two battery setup when I first got a car and into car audio. I got 3 amps running. I had a 4ch Alpine v12 for my surrounds and 2 Memphis 1000D's brigded to power a 15inch CV Stroker at 2 ohm. Happy to say I busted 143.8dB with a sandbag on the gas to keep my alternator running enough juice even with 2 batteries.
Now as an Electrical Engineer I understand what was happening more.
The big problem with two batteries in parallel to maximize the energy demanded needed to power such a big setup is when the charging system is not running ie your car is not running. The two batteries form a closed circuit. Every battery has its own voltage and internal resistance based on the efficiency of the chemical reaction. When connected into a circuit as you would in your car, current will flow and will discharge the higher potential battery (higher voltage) down to the lower potential. Beyond that point current drop because it is now in equilibrium. During operation when your car is running and charging system engaged, the voltage difference is droped over the internal resistance in the higher potential battery, thus providing a single voltage source to the car.
Whats recommended to do is install a battery isolater. Its basically two large, high current diodes (50-100A) that allow current to flow down from your charging system into each battery independently and disallow any current flowing between batteries. It basically allows you to operate two batteries indenpendently while charged with one system. So you hook up your HU, Montiors, and other accesories on battery A and have your amps on battery B with a capacitor for high insantanious current draw when your bass highs to say.
Another option is a high current circuit breaker. It looks like a .5 Farad cap, with a remote turn on. This would be wired in line to the battery B on the (+) and would be activated by either remote turn on from your HU or ignition ON/RUN. While ignition OFF, in either ACC or neutral key positions, battery B is not connected in a circuit with battery A. Thus gainning independence while your car is off.
So having your system connected in the same manor as above in both battery 'isolations', you turn your key to ACC and your HU runs off of battery A and amp on battery B. Start your car or turn to RUN and the batteries are now in parallel. Both setups have the same advantage in that you can always start your car after your amps use up all the juice in battery B.
Hope that will help you and I havn't mislead anything.
Chris
PS Watch for a post of cars pics of mine.
VIP Helen '95 325IS 5sp T-boned
Viva la Victoria '96 328IS 5sp w/ some Dinan
__________________ VIP Helen '95 325IS 5sp T-boned
<a href='http://www.cardomain.com/memberpage/752493' target='_blank'>Car Domain Site</a>
<img src='http://memimage.cardomain.net/member_images/8/web/752000-752999/752493_2_full.jpg' border='0' alt='user posted image' />
Crusin w/ an e46 M3 at 145 on the dial and revs to spare. Saftey with a V1 |
