Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 7-Series
7-Series BMW 7-Series Forum - Covers all the past and present 7-Series including: BMW 750i Sedan, BMW 750Li Sedan, BMW 760Li Sedan. (BMW 7-Series Forum)
Old 09-27-2008, 09:05 PM   #1 (permalink)
Car: 94 740il
Photos: 0
oted is on a distinguished road
radio,94 740il reset
code comes up on the screen on radio because i took battery out of car. so what is the trick to inputting the code so the radio will work. yes i have the code and i tried to put in and the last digit it would beep i did it three times got nothing .
oted is offline   Reply With Quote
Old 09-28-2008, 05:17 AM   #2 (permalink)
marti5's Avatar
Car: E38 1997 735i
Photos: 0
Normally you just punch in the code, however if its the wrong code, or the radio has been replaced at sometime and the code you have is wrong, theres only one way, thats down the dealers, who will pull the radio as on the back is the security code and the radio also is protected via the alarm system. If you go down the dealers take proof of ownership, If however I find out anything else I will get bak to you.
Old 09-29-2008, 09:59 PM   #3 (permalink)
Car: 94 740il
Photos: 0
thanks for the info.
Old 10-07-2008, 01:25 PM   #4 (permalink)
Car: '93 740IL,
Photos: 0
BigT's93 is on a distinguished road
mine did the same thing. It would beep when I was in the middle of punching in the code and manual stated to stop, wait and re enter. I finally just drove the car for about an hour or so and re entered the code and it finally took. hope this helps.
BigT's93 is offline   Reply With Quote
Old 10-07-2008, 06:56 PM   #5 (permalink)
Car: 94 740il
Photos: 0
i still dont have any tunes..ill try your trick this weekend,if that dont work i gotta get different codes
Old 10-07-2008, 07:49 PM   #6 (permalink)
Photos: 0
Resetting the Radio Code
Try this, put key in ignition, turn key to position 1,turn radio to on and wait one hour with key in position 1, then try the code again.
Old 10-07-2008, 08:57 PM   #7 (permalink)
SVK
SVK's Avatar
Photos: 0
SVK is on a distinguished road
Thumbs up
I have a 1994 740il and had the same problem. The one hour thing works. I turned on the key to position one but did not turn the radio on and had it sit for an hour. Then punch in the code.
Good luck.
SVK is offline   Reply With Quote
Old 10-14-2008, 10:04 PM   #8 (permalink)
Car: 94 740il
Photos: 0
tried all of the above,i gotta have the wrong code..its just crazy.
Old 10-15-2008, 04:22 AM   #9 (permalink)
marti5's Avatar
Car: E38 1997 735i
Photos: 0
If you have tried all, then you must have the wrong code, the only way to do it now is take it to an audio fitter whom will plug it in to a comp an recode it/find the code for you.
Old 10-30-2008, 12:46 AM   #10 (permalink)
Car: 1992 735il..500$ beater
Photos: 0
kenjh is on a distinguished road
hi ..I have the same problem with my 735il...but you know I have never heard the sound of a falling leaf hitting the windshield befor...I kinda like my bemmer a little more because of the wonderfull lack of noise ...the dealer here in victoria was no help...but I was warned that would happen....
kenjh is offline   Reply With Quote
Old 11-02-2008, 08:53 PM   #11 (permalink)
Car: 94 740il
Photos: 0
your so right my friend..
Old 11-23-2008, 01:11 AM   #12 (permalink)
Photos: 0
Question radio codes ..intierior lites
well I went for a drive and tried the code and it took !! now the radio works it was the code the dealer had and the same I found in the owners manuel..so the next problem is how to get the intierior lites to come on with the door opening..none of the lites come on except the overhead lites.what switch do I need to turn or is there a setting with the dash computer?...any ideas?
Old 11-24-2008, 07:22 PM   #13 (permalink)
Car: 94 740il
Photos: 0
light switches
all my light switches are on my ceiling,center is off, forward is on ,back lights up my back maybe you have your switches in the center mode.
Old 11-26-2008, 12:25 AM   #14 (permalink)
Photos: 0
ok that was to simple...but the door lites are still not working.the next step is to replace the bulbs .this car is a gas ...I have never had fun figgering out a toy like this since I was a kid..
vB code is On
help with reset e36 radio headcoat 3-Series (E36) 1 09-21-2005 07:25 PM
Need Radio Code For 1992 Business Radio danger450 3-Series (E36) 5 03-07-2005 12:35 PM
To reset or not to reset 007ben 3-Series (E36) 11 07-20-2004 06:35 PM
1995 740il Radio Problem Pe!pe! 6,7,8,X,Z - Series and Mini Cooper 0 06-02-2004 12:38 AM
Dealer Rip - Battery and Radio Reset dakbimmer 3-Series (E46, E90) 2 04-16-2004 11:27 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
