Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 7-Series
7-Series BMW 7-Series Forum - Covers all the past and present 7-Series including: BMW 750i Sedan, BMW 750Li Sedan, BMW 760Li Sedan. (BMW 7-Series Forum)
Old 01-26-2004, 12:10 PM   #1 (permalink)
Photos: 0
BMW740i is an unknown quantity at this point
I just recently purchased a 1995 740i and the car for some reason at the stop light will shutter or shake a little. Anybody have any clue? could it be the oxygen sensor? Any help would be great. Thanks
BMW740i is offline   Reply With Quote
Old 01-26-2004, 05:15 PM   #2 (permalink)
Maz
Photos: 0
Maz is an unknown quantity at this point
Send a message via AIM to Maz
It is most likely the O2 sensors!!! they are cheap to replace and the car runs so much better once they are replaced
Maz is offline   Reply With Quote
Old 01-26-2004, 09:02 PM   #3 (permalink)
EXtech's Avatar
Photos: 0
Three things to look at: Crankcase vent valve, valve cover gaskets leaking, catalytic converters. How many miles are on the car?
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 01-26-2004, 10:19 PM   #4 (permalink)
TECH's Avatar
Photos: 0
There is no way in the world for any of us to tell you what the problem is.
Oxygen sensors are very unlikely to cause a rough idle on these cars. Crankcase vent valve is a likely suspect (it's actually a plate on the back of the intake manifold), valve cover gasket's leaking-not likely, but possible (sucking air, not just leaking oil), catalytic converter-possible, but it would cause problems above idle as well.
You could be looking at a spark plug, fuel injector, ignition coil, idle valve, intake vacuum leak from various sources, a sensor malfunction of some sort (which would usually set a check engine light), bad fuel, etc.
You can check all these things to the best of your ability, but we can't say for sure what the problem is.
Old 01-27-2004, 09:50 AM   #5 (permalink)
EXtech's Avatar
Photos: 0
valve cover gaskets leaking= vacuum leak and oil in the spark plug cavities (misfire)
Catalytic converter can cause problems at idle but have yet to create a noticeable problem above idle (i say this because i've seen it).
Any vacuum leak will cause a rough idle. It seems you should have the vehicle looked over if you don't feel confident yourself. Has your Check engine light come on?
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 01-27-2004, 06:31 PM   #6 (permalink)
CLW
Photos: 0
CLW is an unknown quantity at this point
For what it is worth I have a '97 740il. About 2 years ago with about 65K on the odometer it began a subtle miss almost exclusively during warm up idle. Initially it would clear within 3-4 minutes. Felt like a mildly fouled single plug but was irratic occurence wise, not always happening. Gradually occurences became more noticable but still subtle, not enough to really stop and go after. Always at idle and never above 1000 rpm it finally set the check engine light. Took it to the dealer and was the convertors. Funny thing was even at the end it was not every time you started it and almost imperceptable when warmed up.
CLW is offline   Reply With Quote
vB code is On
choice in spark plugs for 95 740i e38 kc740i 7-Series 2 11-13-2005 11:12 AM
Urgent Help - Cant get into boot on my 740i fuzioneer 7-Series 2 09-12-2005 06:14 PM
Looking For 1995 740i Carpet & Audio/video Options gezzuzz 7-Series 0 03-10-2005 01:42 PM
2002 E39 530da Shaking When Idle larscph 5-Series (E12,E28, E34, E39, E60) 11 11-12-2004 02:08 AM
2001 740i navigation on a 98 740i bmw. nap21 Audio and Electronics 4 11-09-2004 06:31 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
