» Sponsors
» Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 7-Series
7-Series BMW 7-Series Forum - Covers all the past and present 7-Series including: BMW 750i Sedan, BMW 750Li Sedan, BMW 760Li Sedan. (BMW 7-Series Forum)
Old 11-11-2009, 03:52 PM   #1 (permalink)
Photos: 0
timindp is on a distinguished road
Driver Side Seat and Steering wheel DEAD!
Ok, I change the fuse (30amp) and the seat and steering column works for about 2 minutes, then it dies. I am assuming there is a short somewhere. Has anyone had this issue?
1999 740i
timindp is offline   Reply With Quote
Old 11-11-2009, 10:05 PM   #2 (permalink)
Car: 1990 BMW 735iL
Photos: 0
beamers4life is on a distinguished road
First i would look underneath the seat and see if your seat has pinched or mashed or cut any wires that may have come unfastened from the rail. If none are visible then it sounds like you may have a relay issue which are located in the front fusebox and underneath the rear seat behind the drivers seat. If a wire has not been mashed pull these relays out one at a time and see if any of the protruding contacts appear to be burnt and have a black discoloration on the surface. If this is the case with one of them then most likely it is shorting out and i would suggest replacing them. Those are the only two possibilities i can think of unless you have a short in the steering wheel wiring which is unlikely and also difficult to access. So i would suggest checking these first. Keep us posted.
beamers4life is offline   Reply With Quote
Old 11-11-2009, 10:32 PM   #3 (permalink)
Car: 530i-2002 & E280-2007
Photos: 1
rashid is on a distinguished road
Check the connection of the Seat control module behind the driver seat trim.
If this connection is lose then the seat control, steering control & even the memory will not work
rashid is offline   Reply With Quote
Old 11-12-2009, 02:53 AM   #4 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 735i
Photos: 0
As said under the seat connections/wire chaffed...common problem on a 7 series.
Old 11-12-2009, 10:14 AM   #5 (permalink)
Photos: 0
The wiring under the seat looks good. Nothing was loose nor broken. I looked in the fuse box, could not see anything else burned.
Old 11-12-2009, 10:54 AM   #6 (permalink)
marti5's Avatar
Car: E38 1997 735i
Photos: 0
If the wiring is faulty on the drivers side the passenger seat will not operate, check that.
Old 11-12-2009, 11:29 AM   #7 (permalink)
Photos: 0
Passenger side works fine
Old 11-12-2009, 11:47 AM   #8 (permalink)
marti5's Avatar
Car: E38 1997 735i
Photos: 0
Ok, you say you have changed on fuse....
Drivers seat is fuse #15
Steering wheel is fuse # 12
If either of the above have gone they will affect the other....
Old 11-12-2009, 11:54 AM   #9 (permalink)
Photos: 0
my #12 is blank, not used or no use. The 15 slot works for both the driver seat and steering column
Old 11-12-2009, 11:59 AM   #10 (permalink)
marti5's Avatar
Car: E38 1997 735i
Photos: 0
Do you have a multimeter, check you have 12v feed to the fuse its self, if yes, then check for 12v to the seat, then drop the steering cowl, there may be a loose connection in there.
Old 11-12-2009, 12:02 PM   #11 (permalink)
Photos: 0
Thanks for all the input. I don't have the necessary tools. Looks like I am headed to the mechanic.
Old 11-12-2009, 12:13 PM   #12 (permalink)
marti5's Avatar
Car: E38 1997 735i
Photos: 0
Ok.....to run one of these beasts you really need diagnostics kit( carsoft 6.5 is a good one for DIY) and the tools, or they will cost you $$$$$$$$...hope you get it sorted
Old 11-30-2009, 04:51 PM   #13 (permalink)
Car: 1997 BMW 750il only 30k on it!
Photos: 0
RckyMtn760 is on a distinguished road
I have the same problem. Passenger seat works. Seat will go backwards on occasion with the switch. Does no recline but the headrest goes up and down. Steering wheel sometimes will move up and down but not telescope anymore.
RckyMtn760 is offline   Reply With Quote
Old 12-01-2009, 04:05 AM   #14 (permalink)
marti5's Avatar
Car: E38 1997 735i
Photos: 0
Have you checked all the above mentioned??
Old 12-01-2009, 09:59 AM   #15 (permalink)
Photos: 0
Not yet. It just happened after a trip through the mountains. Once I get back to my garage I will check it
vB code is On
Driver Seat, Memory & Steering wheel control rashid 5-Series (E12,E28, E34, E39, E60) 2 09-13-2009 03:27 AM
How to fix driver side seat plastic mold from falling off! prmoorman1 5-Series (E12,E28, E34, E39, E60) 0 08-13-2008 10:35 AM
Driver Power Seat and steering wheel problems wabenzy 5-Series (E12,E28, E34, E39, E60) 4 07-09-2008 10:35 AM
Power seat/steering adjusters dead mrogers 5-Series (E12,E28, E34, E39, E60) 11 01-03-2006 10:38 PM
Driver Side Sport Seat For 87 325 Convertible H2OVIS 3-Series (E21, E30) 0 12-15-2004 02:13 PM
