Hi Guys, the saga continues...
another local BMW trained techie arrived to view the beast on Saturday morning and the following was tried.
Idle valve cleaned, it was filthy inside and a good wash out with thinners got it working smoothly.
Co2 was at 3% initially but we then changed the Lambda sensors and the Co2 reading increased to 11%.......fault codes were flagged up on both sets of lambda sensors, the old BMW ones and the new aftermarket ones
Fuel now present in oil so we changed the oil and oil filter.
No other fault codes present apart from an inoperative charcoal filter on the fuel tank purge system which is hardly surprising as we havent fitted the filter but have blanked the tube off anyway. This we are told by everyone who has looked at the car will have no effect on the engine as its a requirement for smog control legislation not engine management.
Introducing an air leak after the MAF sensor worked for about 15 seconds as the Co2 dropped to 9% and then the bloody car reacted, compensated for the air leak and Co2 went up to 11% again.
All sensors on the engine good with correct temperature readings on both inlet and outlet water temperature sensors.
It appears that the problem, may not be of our making and that the overfuelling may have been occuring in the original 740i.
All hoses and unions and exhaust joints gas and airtight. The induction system is non standard with a huge green cone type filter ( non oiled) feeding through a large flexible leak proof ducting from the front of the car ( cool air) into the throttle body ie no restrictions etc. Taking off the oil filler cap had no effect on the emissions so crankcase ventilation still working ok.....
The plan is next Saturday to get two new BMW Lambda sensors, and borrow another DME, plus key, plus EWS box, to see if its the DME causing the problem........which it very well could be....
More updates later in the week.
Cheers,
Tony
Good news is that all the techies and garages who have looked at the Cobra have not charged me for their time as they cant fix the problem. One had his guys working on it for three days and didnt charge me a penny......I had to promise to take him for a ride in the car when its legal however..... :P
