Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6-Series
6-Series BMW 6-Series Forum - Covers all the past and present 6-Series including: BMW 650i Coupe, BMW 650i Convertible, BMW 645Ci, BMW 630i, BMW 650i, BMW 635d, BMW 635i. (BMW 6-Series Forum)
Old 05-08-2005, 03:35 PM   #1 (permalink)
Photos: 0
jq740635 is an unknown quantity at this point
Restoring a 85 635 csi. Really coming along nicely except for a few nagging problems. Had a power steering pump whine and decided to get a new pump. Put the new pump in and it still whines. The whine will go away after 15 minutes?! Do I have an airlock problem or similar? Do I bleed something? The speedometer also does not work. I have researched a bit and it seems there is no cable but a sensor/pickup. Is this where my problem is? Any advice is appreciated. Great site!
jq740635 is offline   Reply With Quote
Old 05-09-2005, 12:10 AM   #2 (permalink)
Photos: 0
to bleed the P/S of any air just have the car running and turn the wheel bcak and forth from each end of the travle about 5-10 times each way. this should get rid of most if not all the air that could be trapped in the lines. also check the alternator and the water pump to amke sure they are not the culprit of your whine. as for the speedo i don't remember exactly how that works and i don't want to give you any false information. hopefully someone else can shed some light on this topic.
Old 05-09-2005, 07:44 AM   #3 (permalink)
slyhog-22056's Avatar
Photos: 0
slyhog-22056 is an unknown quantity at this point
Send a message via Yahoo to slyhog-22056
The speedometer is ran by a pickup in the rear end diff cover, inside is a toothed ring that pulses as you drive sending info to the dash assy, on my guage cluster there is a pair of connectors about midway below the speedo location, I believe the blue one is speed and white is tach. If they are plugged in find another pickup sensor at a wrecking yard and substitute it for yours and try it before you buy a new one, they arent cheap.
slyhog-22056@sbcglobal.net
Wm. D. Cunningham
My 1984 BMW 633 CSi Pictures:
http://www.roadfly.com/bmw/gallery/p...37076,1;-24,1;
slyhog-22056 is offline   Reply With Quote
Old 05-09-2005, 06:14 PM   #4 (permalink)
Photos: 0
The more I turn the wheel, the louder the whine so I do believe it is ps pump or system related. When I put the new pump in, it was quiet for one minute, than started whining. I am at a loss!
Old 05-09-2005, 09:22 PM   #5 (permalink)
Photos: 0
does the power steering still work when the noise is present. or do you notice any certian spots when turning the weel that the power steering seems like it isn't working? and did you use the right fluid? i don't know if that cars uses ATF or the 11S. but either way the cap should say what should be used.
vB code is On
Newbie question(s) on engine maintenance Morgenster 3-Series (E21, E30) 9 12-19-2005 08:32 AM
Sorry for being a newbie, 523i se questions Byron320i 5-Series (E12,E28, E34, E39, E60) 3 09-14-2005 07:28 PM
Newbie Owner Questions Yadatsgud 3-Series (E36) 3 06-01-2004 10:24 PM
Newbie questions on shifting crisdoc 3-Series (E46, E90) 2 01-28-2004 11:46 AM
Couple questions from a newbie playtothebeat 5-Series (E12,E28, E34, E39, E60) 1 09-15-2003 09:20 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
