Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6-Series
6-Series BMW 6-Series Forum - Covers all the past and present 6-Series including: BMW 650i Coupe, BMW 650i Convertible, BMW 645Ci, BMW 630i, BMW 650i, BMW 635d, BMW 635i. (BMW 6-Series Forum)
Old 07-09-2008, 02:34 PM   #1 (permalink)
Photos: 0
Phantom25 is on a distinguished road
89 635 Gas Tank Brain Teaser
Yesterday here in Las Vegas it was hot (108F) so I was travelling across town with the air conditioning on in afternoon rush hour traffic -- lots of stop/start traffic. Wanting gas, I stopped at a service station, turned off the air conditioning first and then the car. Opened the refueling door and as I unscrewed the gas cap, pressure from the tank pushed the cap away from the filler tube. Looking down the filler tube the gas was bubbling (like it was cooking or boiling) and you could feel pressure comng out of the tube. It continued to do this for a good ten minutes. When it stopped bubbling I elected not to fill the tank, replaced the cap, drove the five minutes to the house, parked it in the driveway, opened the gas cap and hood and let it sit for an hour while I called my mechanic with 28 years of Beemer experience. He said that he never heard of such a thing but will check through his contacts. I, in turn, thought I'd try this forum to see if anyone else ever experienced this.
To Recap: outside temp was 108F; air conditioning was on; heavy rush hour traffic with numerous stop/start situations; semi aggressive driver; gas tank was half full at the time; no indications on any of the gauges that anything was going wrong; when unscrewed gas tank pressure forced the cap away from the filler neck; bubbling gas was observed in the filler tube and lasted about ten minutes.
Anyone got a clue???????
Phantom25
Phantom25 is offline   Reply With Quote
Old 07-09-2008, 04:57 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 99 C43 AMG, 89 300SEL
Photos: 0
Send a message via Yahoo to darkhorse737 Send a message via Skype™ to darkhorse737
Talking
re-check your EVAP line routing... you may have crossed them with vacuum lines.
ay sino caddi ububblaem? Heaven won't take me; and Hell just knows I'll take over...!
Old 07-24-2008, 05:02 PM   #3 (permalink)
Photos: 0
Been away for a while but finally back at the boards.
First -- Thanks for the heads up Darkhorse but that wasn't it.
The car went in the same day I posted the original and I finally got a call to pick it up yesterday. My guy with 28 years went through every possible pump, check valve, cleaned all gas and vaccum lines. Refilled tank to same level as when the problem developed drove it several times when the temperature neared or was the same as the problem time. Dropped the gas tank, checked the innereds and the lines that ran inside the trunk under rear shelf under the rear window. Checked fuel pressures and all were within tolerances. Finally noted that the vapor expansion tank in the trunk would expand a little more then normal. When it expanded the bubbling would occur indicating gas trying to return to the tank. When tested the tank was found in tolerance even when expanded. The only other possible cause as explained to me is that the new additives being added to the fuel now could be the prime contributing factor. I looked at my Pro questioningly but since every fuel, feeding, and vaccum system was found to be in working order I couldn't argue with him. I'm going to be watching it in the future against all weather conditions.
vB code is On
Piss in gas tank. d3ity 5-Series (E12,E28, E34, E39, E60) 16 08-22-2007 01:17 AM
rubbing alcohol in your gas tank ? j123crx 3-Series (E21, E30) 2 11-01-2005 08:40 PM
E30 Gas Tank e30man 3-Series (E21, E30) 4 02-12-2005 06:00 PM
Air Noise Comming From Gas Tank victorgallas 3-Series (E36) 0 01-21-2005 11:14 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
