Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6-Series
6-Series BMW 6-Series Forum - Covers all the past and present 6-Series including: BMW 650i Coupe, BMW 650i Convertible, BMW 645Ci, BMW 630i, BMW 650i, BMW 635d, BMW 635i. (BMW 6-Series Forum)
Old 05-30-2006, 01:53 AM   #1 (permalink)
Photos: 0
d3ity will become famous soon enoughd3ity will become famous soon enough
635csi woes, What should I do
Alright, I've got a 1985 635csi. Here's my situation.
The car has been sitting for over a year, the A-clutch on the transmission is fried. The tranny fluid seems burnt, and it's stuck in gear.
Meanwhile, the car has begun to rust into the ground. I've been doing my best to keep it away, but basically, my passanger side quarterpanel around the wheelwell is toast, needs to be cut out and have a new piece welded in. Bondo isn't cutting it.
A new transmission for the car, another automatic (which is what caused the problem) will run me 400-700 dollars. I have no way of moving the car, so I'd have to have it towed out, with the transmission still in gear... Meaning I would have to block up the tires, and disconnect the driveshaft.
The other option I have is a manual tranny conversion. I haven't been able to figure out just what I'd need, but I'm planning on calling bavarian auto recycling for a quote... This would mean me praying to god that I don't have to replace the entire ECU...and hoping that I'd be able to do this for under a grand.
What would you guys suggest I do about this? I'm really not sure which option to take here. I'd be doing all the work myself, meaning the cost of a set of jack stands (hopefully will get the car high enough to drop the tranny out) or towing it to a shop where the work can be preformed for an exorbanant rate). As for the rust, well, I'd have to find a car and cut the quarterpanels, and one of the front fenders off of it.
Also, FYI, there are three diffrent automatic transmissions for the 1985 635 CSI, I cannot for the life of me get under the car to identify which one I have. Is there an easier way to get this information? and where exactly on the transmission would it be located?
d3ity is offline   Reply With Quote
Old 05-31-2006, 04:50 PM   #2 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Photos: 1
Try this link for additional info/help
http://www.bmwworld.com/models/e24.htm
LOS
FOUND A BETTER ONE!!!
http://normgrills.net/bcg/
Old 05-31-2006, 06:07 PM   #3 (permalink)
Photos: 0
What the page neglects to report is that there are in fact 6 diffrent transmission styles for that car. Electronic with CV Joint, 4 bolt Electronic, 3 bolt electronic, CV joint hydraulic, 4 bolt hydraulic, and 3 bolt hydraulic.
The manual trans, however, comes in one style. Hopefully i'll be able to get one of those.
Old 05-31-2006, 06:19 PM   #4 (permalink)
LOS
LOS's Avatar
Photos: 1
I also happen to have a phone number and email address from someone @ Gault BMW. He's very helpful even if you do not buy anything from them. I'm sure he can tell you where to find those darn numbers and what it would take for the swap. Just trying to help!
Al.Shattuck@GaultAuto.net
1-800-777-5508
LOS
Old 06-01-2006, 12:56 AM   #5 (permalink)
Photos: 0
Thanks alot man, I'll probably be in contact with him in the next few days to try to figure out which transmission is in this vehicle, since it's impossible to read anything underneath that car since its practically impossible to get underneath that car.... I've got like 3 inches of ground clearance. It's awesome.
Thanks alot man.
Old 09-26-2007, 04:24 PM   #6 (permalink)
Teh whore
AlpineSixAndSeven's Avatar
Car: 1986 325es, 1987 635CSi, 1976 Benz
Photos: 0
Thumbs up
go for the maunal conversion I am doing it on my mercedes Benz. It will be totally worth it. You'll need a manual transmission, clutch kit, flywheel, slave cyl., master cyl., clutch line hose, and pedal assembly, shifter, shift knob and boot i dont know about the electronics of this car yet(getting mine sunday but if you need and pics of the 5 speed stuff just post what you need) but im sure it can be bypassed but go for it i loved my 5 speed e30 and im sure ill love my 5 speed 633. and im sure you will love it if your 635 was a 5 speed
Originally Posted by drz View Post
I'll never be bound to no man by means of a piece of paper
Originally Posted by My Auto Trans Teacher View Post
Butt plugs saved my life
Old 09-26-2007, 05:04 PM   #7 (permalink)
drz
master of his domain
drz's Avatar
Car: e36 2.8i; e46 zhp
Photos: 0
Another über old thread. d3ity drives an E34 now.
Turkey Fleet Bond Holder
Old 09-26-2007, 06:58 PM   #8 (permalink)
Photos: 0
Yeah, but my e24 still occupies a place in my garage... Just waiting for the right time/right paycheck to make my move.
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
Old 09-26-2007, 08:35 PM   #9 (permalink)
Teh whore
Photos: 0
i figured he would still have it i just wanted to tell him he should go for it and tdo the 5 speed swap
Old 09-26-2007, 09:36 PM   #10 (permalink)
Photos: 0
Yeah... I could never... ever bring myself to sell that car... it's far too pretty... and it's pretty damn fast.
Old 09-27-2007, 04:20 PM   #11 (permalink)
Teh whore
Photos: 0
yeah the 6 series just looks sporty to my havent driven one yet so ill take your word on the perm. of the car but you should do the conversion and bring him/her back onto the road someday sry bout the OLD post revivel thing just really happy i am getting my 6 on sunday(towing him home will have MANY pics) do you have pics of your 6?
Old 07-09-2008, 12:59 AM   #12 (permalink)
Photos: 0
omorales is on a distinguished road
you should just buy my 6 lol anyways i think you are going to have to swap out the ecu if you want to do the manual tranny swap, i swapped out the tranny from an auto to a stick on my old nissan 240 and i had to get the harness and ecu from a manual car to do it, but of course its a nissan not a bmw.
btw
http://www.bimmerwerkz.com/forum/car...bmw-57939.html
omorales is offline   Reply With Quote
Old 07-13-2008, 01:53 AM   #13 (permalink)
Photos: 0
6er is for sale at the moment for the right price... it's time for her to go to a better home.
Old 07-13-2008, 02:56 AM   #14 (permalink)
Teh whore
Photos: 0
lol I ended up buying a 87 635 for $500 wish i could buy it it is purdy.... sry D i can get you sixer.... mom said she'll kill me if i bring another car home.... even though i'm looking at a civic....
Old 07-15-2008, 12:49 AM   #15 (permalink)
Photos: 0
my 6 is still for sale
vB code is On
2 great 6's for sale!!!! 635csi - M6 steveb56 Classifieds Sell & Buy 1 04-25-2008 09:44 PM
Question on a 635csi alpina.... JAEgerrr13 6,7,8,X,Z - Series and Mini Cooper 2 11-14-2005 05:30 PM
Parting Out '80 635csi Euro (potentially) calereeves 6,7,8,X,Z - Series and Mini Cooper 1 12-01-2004 11:40 PM
FS: 89 635csi (E24) xplodersport96 Classifieds Sell & Buy 4 01-08-2004 09:48 PM
635csi power seats WI635csi 6,7,8,X,Z - Series and Mini Cooper 1 12-20-2003 01:18 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
