Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 12-07-2003, 05:42 AM   #1 (permalink)
Photos: 0
tcpgv is an unknown quantity at this point
Mercedes Benz ML430: From 0-60 problems and 60 days of service in 4 years.
My Mercedes Benz ML430 Year 2000 (50000 miles) has had more than 60 problems, and 60 days of service in less than 4 years.
I had to return the vehicle on 20 or more occasions to Autonation/Smythe European (the dealer) for warranty repairs. Currently Mercedes Benz has indicated that they will repurchase the car within 3-4 weeks.
Should I get a BMW X5?
Is it reliable?
Does it have a lot of small, medium or large problems?
I have included a list of my ML430 problems below.
60 Problems in 4 Years
1. Brake system defect, ESP pump leak fixed
2. Windshield wiper motor defect, replaced
3. Door malfunction, latch replaced
4. Door maladjusted, fixed
5. Navigation system malfunction
6. Door malfunction, R/R door actuator replaced
7. Washer reservoir leaking, replaced
8. Stop lamp switch malfunction
9. Fuel filter replaced
10. Gas door actuator malfunction
11. AC system defect, fan speed switch knob replaced
12. Gas door lock replaced
13. Sunroof defect, seal replaced
14. Loose washer causing rattle inside left rear door replaced
15. 3rd brake lamp cover that pops of replaced
16. Inside trim panel tabs top defective
17. Right side washer nozzle replaced
18. Command center malfunction, navigation system replaced
19. Engine problem, right rear 02-sensor causing engine light on replaced
20. Door malfunction, right rear door lock replaced
21. Front brake pads and rotors changed, not covered by warranty
22. Missing sunroof guide clip replaced
23. Sliding sunroof shade tightened
24. Dents and dings fixed, not covered by warranty
25. Cracked left front lower seat plastic replaced
26. Sunroof defect, rattle caused by sunroof frame replaced
27. Front brake pads replaced, not covered by warranty
28. Jammed left rear seatbelt fixed
29. Door malfunction, door lock actuator replaced
30. Brake pad wear sensor causing brake warning light replaced
31. AC defect, fuse and harness causing auxiliary fan to malfunction replaced
32. AC defect, blower causing noisy HVAC replaced
33. Rattle from roof console caused by rattling sunroof motor connectors fixed
34. Door malfunction, lock actuator replaced (both)
35. Door malfunction, squeaking door lock, not verified
36. Defective fuel door lock replaced
37. Stop lamp switch causing Bas ESP light on replaced
38. Wheel alignment, not covered by warranty
39. Worn tires replaced, not covered by warranty
40. Clamp on lower P/S hose recalled and replaced
41. Rear pads replaced, not covered by warranty
42. Loose insulation at right front window replaced
43. Wire causing CD Changer error fixed
44. Door malfunction, rear door cable rerouted
45. Window defect, loose insulation causing problems with left front window replaced
46. Window defect, window switch replaced
47. Defect CD Changer replaced
48. Loose right rear door insulation panel replaced
49. Door malfunction, right rear door actuator replaced
50. AC defect, blower vibration, not verified
51. Cracked steering wheel replaced
52. Defect rear pillar decals replaced
53. Defect front pillar decals replaced
54. AC defect, defective center dash vent replaced
55. Door malfunction, left rear door actuator replaced
56. Door malfunction, left front door actuator replaced
57. Window washer nozzles clogged, not covered by warranty
58. Cracked window reservoir replaced
59. Defective fuel filter replaced
60. Door malfunction, defective door actuator replaced
61. Power steering hose recalled and replaced
62. Alarm system defect, going off randomly, recoded
63. Navigation system defect, randomly shows incorrect location, not verified
tcpgv is offline   Reply With Quote
Old 12-07-2003, 06:03 AM   #2 (permalink)
6th Gear Member
lwebb12's Avatar
Car: 2000 M5
Photos: 0
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
i dont think the X5 has a list of problems like that. i know a few people who have them and no one has said anything like that
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Old 12-07-2003, 10:48 AM   #3 (permalink)
Photos: 0
the///man is an unknown quantity at this point
weve had ours for 3 years. we havent had ONE SINGLE problem. just ruitine oil changes and filter changes. other than that we had a scratch buffed out and thats it. get the 4.4 though its a v8 and has 290 hp. plus it looks way better than the mercedes B)
the///man is offline   Reply With Quote
Old 12-08-2003, 06:07 PM   #4 (permalink)
Photos: 0
Mr.X5 is an unknown quantity at this point
I never had any problem of those
<img src='http://tecdoc.ru/catalog/bmw/img/bmw_x5.jpg' border='0' alt='user posted image' />
Mr.X5 is offline   Reply With Quote
Old 12-10-2003, 01:30 PM   #5 (permalink)
Maz
Photos: 0
Maz is an unknown quantity at this point
Send a message via AIM to Maz
Our 4.4 X5 has never had any problems!!! It runs great!! It would definately be a better buy then getting a new merc
Maz is offline   Reply With Quote
Old 12-17-2003, 12:27 AM   #6 (permalink)
Photos: 0
crispins is an unknown quantity at this point
I have had a 3.0 and now a 4.6 and have not had to have either repaired once.
The trucks seems very well built.
I think you would be happy with BMW.
I will not own a Benz as alot of the people I know who have them have nothing but problems with them.
crispins is offline   Reply With Quote
Old 03-30-2004, 03:51 AM   #7 (permalink)
Photos: 0
rting is an unknown quantity at this point
Whoa! I thought the list is really impressive - from the perspective of keeping track of it!
I would still get the X5 4.4i. It is probably more reliable than the ML but I reckon it is no Lexus. Also, http://www.consumerreports.org/ have some interesting info.
Before you buy, you may want to check out the following list (updated 2004/3/30) - although not as long as yours - they are posts that highlight some of the issues ... list is divided into types of problems.
Transmission/throttle delay
http://www.automotiveforums.com/vbulletin/...ad.php?t=204656
http://bimmer.roadfly.org/bmw/forums/e53/4818401-1.html <- throttle delay problem! Dangerous!
http://bimmer.roadfly.org/bmw/forums/e53/4881713-1.html
http://www.bimmerfest.com/forums/showthread.php?t=56003
http://www.bimmerfest.com/forums/showthread.php?t=54548
http://www.bimmerfest.com/forums/showthread.php?t=55703
http://www.bimmerfest.com/forums/showthread.php?t=54748 <- This is for the X3!!!
http://bimmer.roadfly.org/bmw/forums/e53/4843283-1.html
http://bimmer.roadfly.org/bmw/forums/e53/4845410-1.html
http://bimmer.roadfly.org/bmw/forums/e53/4829223-2.html
http://bimmer.roadfly.org/bmw/forums/e53/4842227-2.html
http://bimmer.roadfly.org/bmw/forums/e53/4840630-3.html <- a "known problem"!
http://bimmer.roadfly.org/bmw/forums/e53/4819901-4.html
http://bimmer.roadfly.org/bmw/forums/e53/4776168-4.html
http://bimmer.roadfly.org/bmw/forums/e53/4807832-5.html
http://bimmer.roadfly.org/bmw/forums/e53/4843862-1.html
http://bimmer.roadfly.org/bmw/forums/e53/4883060-2.html
http://bimmer.roadfly.org/bmw/forums/e53/4872225-2.html
http://forums.bimmerforums.com/forum...d.php?t=190233
http://www.automotiveforums.com/vbulletin/...52&page=2&pp=15 <- plus info on shifting from P to D delays.
Leaky fuel injectors leading to potential engine fire!
http://www.automotiveforums.com/vbulletin/...ad.php?t=197252
Frontend control arm replacements!
http://bimmer.roadfly.org/bmw/forums/e53/4884289-1.html
Brake pad low light did not came on
http://bimmer.roadfly.org/bmw/forums/e53/4885267-1.html
Brake line
http://forums.bimmerforums.com/forum...ad.php?t=72258
Instrument Cluster
http://bimmer.roadfly.org/bmw/forums/e53/4814609-4.html
SES light
http://bimmer.roadfly.org/bmw/forums/e53/4850936-1.html
Airbag Indicator Light
http://bimmer.roadfly.org/bmw/forums/e53/4854517-1.html
Interior Door Handles:
http://bimmer.roadfly.org/bmw/forums/e53/4829144-1.html
Poor Service:
http://bimmer.roadfly.org/bmw/forums/e53/4833214-3.html
Radio:
http://www.bimmerfest.com/forums/showthread.php?t=54147
Just bad overall:
http://bimmer.roadfly.org/bmw/forums/e53/4872225-1.html
http://www.automotiveforums.com/vbulletin/...ad.php?t=173967
Roger
Vancouver, BC, Canada
Buying a 2004 BMW X5 4.4i ... really soon
My web site: <a href='http://www.angelfire.com/bc/rogerting/Strategy.htm' target='_blank'>http://www.angelfire.com/bc/rogerting/Strategy.htm</a>
rting is offline   Reply With Quote
vB code is On
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
