Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 06-13-2004, 07:38 PM   #1 (permalink)
Photos: 0
1scoot is an unknown quantity at this point
My 94 740IL's driver side power window will not go up or down. All the other windows work as they should. The motor is fine because I can put 12 volts directly to the motor and make it go up or down. The switch is fine because I put in another switch and got the same results. It also makes a click sound under the rear seat when I press the switch in either direction which leads me to believe the switch is good. I put a multimeter on the plug at the motor and it is getting 9 volts in either directions. Has anyone else had this problem? I'm guessing there must be some sort of voltage regulator problem? Any suggestions are appreciated.
1scoot is offline   Reply With Quote
vB code is On
Intermitient Operation Of Drivers Side Door Window mudilik 5-Series (E12,E28, E34, E39, E60) 1 08-18-2005 10:56 PM
Window Trouble Sporty540 5-Series (E12,E28, E34, E39, E60) 4 01-11-2005 12:49 AM
Rear Defrost Window Half Working? Paraklas 3-Series (E21, E30) 8 11-28-2004 12:07 AM
Power Window And Door Lock Problem...96 750il moabxj01 7-Series 1 11-16-2004 04:30 PM
Passenger Window Exterior Trim epistemology 3-Series (E36) 5 09-27-2004 04:28 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
