Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 05-07-2007, 11:06 PM   #1 (permalink)
Photos: 0
Badmnky is an unknown quantity at this point
Will 93 740il lock motor with low oil?
My wife was driving home and said the car just stalled out like it was out of gas. I noticed the red oil light was on (as well as "low oil" in the message board...aagghhhh!) and put in 3 quarts to bring it to level. The car turns over but will not start. It sounds as if it isn't getting any fuel. I suspect the fuel pump may have gone but I recall hearing that if the oil gets too low the car will shut itself down.
All lights are still on after topping off. Thank you for any input.
Badmnky is offline   Reply With Quote
Old 05-08-2007, 07:47 AM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Photos: 0
Sounds more like a fuel issue than an oil issue.
The oil light might be a bad sensor as well.
1995 E38 740iL. Highly modded. Faster than you.
Lindsay fan club member.
Old 05-08-2007, 09:23 AM   #3 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Photos: 1
Have you try removing the fuel pump fuse and placing it back on?
I don't remember the fuse number but I believe is in the trunk area by the battery. I have heard this is how you re-set the fuel pump to release or bring back the pressure.
LOS
Old 05-08-2007, 02:01 PM   #4 (permalink)
Photos: 0
Yes, I did R&R the fuse. I also tried the "magic reset" and pinning 7 & 19 while turning the ignition to the "run" position. None of that worked. I'm going to replace the fuel filters (I have a sneaking suspicion they have never been replaced) and see if the pump is working. Thank you for your input. I'll update later.
Old 05-12-2007, 07:52 PM   #5 (permalink)
Photos: 0
Yippeee
Replaced the fuel filters and she's running like a champ. I'm willing to bet they were the original filters. I couldn't blow through them. 191k
vB code is On
Oil drain plug *HELP* topless_328 3-Series (E36) 15 12-06-2006 04:10 PM
oil leaking from a few places... yammahamma 3-Series (E21, E30) 31 11-02-2006 10:28 PM
325i 1000 miles and low oil? djfrankie 3-Series (E46, E90) 8 05-29-2006 06:22 PM
Oil additives and the damage they do. Starmavin 3-Series (E21, E30) 2 05-18-2006 01:49 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
