Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 11-10-2007, 08:18 PM   #1 (permalink)
vwtourbus's Avatar
Car: 97 Jetta,92 BMW 735I
Photos: 0
vwtourbus is on a distinguished road
radiator fan
I have a 92 735i that I have converted the ac to r134 and my high speed fan wont come on. When its hot out, at idle, the ac will shut off because of high ac pressure due to the high speed not working. The fan comes on low speed but not high. Is the problem the fan or the high pressure switch. Also do I have to evacuate the ac system to change the high pressure switch?
vwtourbus is offline   Reply With Quote
Old 11-11-2007, 07:49 AM   #2 (permalink)
Photos: 0
Fan
You can check pressures, but I would guess the AUX fan switch (located on your car, I believe,in the upper portion of the radiator, passenger side) may be bad.
Old 11-13-2007, 09:43 PM   #3 (permalink)
vwtourbus's Avatar
Photos: 0
Wouldnt the high pressure switch over ride the thermal switch on the radiator if the ac pressure rises too high? Are the fans wired from the relays through the thermal switch? Or could the high speed relay be inop? Sorry for all the Q's but i want to figure this out and BMW are very different than VW that Im used too.
Old 11-14-2007, 07:01 AM   #4 (permalink)
Photos: 0
Fans
Fans are wired through the relays but directly connected if the AC is engaged, the switch determines fan speed (hi/lo). I sent you a private message and if you respond you will have the BMW ETM (I hope).
Old 11-14-2007, 07:19 AM   #5 (permalink)
Photos: 0
BMWE38.Org - The 95-01 BMW 7 Series Owners Reference
Everything you want to know and more.
Old 11-14-2007, 07:21 AM   #6 (permalink)
Photos: 0
make it e38.org BMW 7-series information and links
Old 12-02-2007, 07:25 PM   #7 (permalink)
vwtourbus's Avatar
Photos: 0
Thanks for the info. Ill check it out but right now I have to figure out why my rear defrost doesnt work.
Old 12-02-2007, 08:08 PM   #8 (permalink)
Teh whore
AlpineSixAndSeven's Avatar
Car: 1986 325es, 1987 635CSi, 1976 Benz
Photos: 0
^ lol that sucks... does the button work show power?
Originally Posted by drz View Post
I'll never be bound to no man by means of a piece of paper
Old 12-03-2007, 06:18 AM   #9 (permalink)
vwtourbus's Avatar
Photos: 0
Yup, an fuses are good. Im thinking a relay is not working because the switch works and the light in the switch vomes on just now poer to the rear window. I read some where the control module for the heating and ac behind the sword may have something to do with it.
vB code is On
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
