Our 3157 Kits are now available at
http://www.jlevisw.com in both Amber and Xenon.
They are $40
This kit includes everything you need to convert your front corners to LEDs:
-(2) 3157 LED Bulbs (Each 24 LED Matrix Design)
-(2) Load Equalizers to eliminate "Bulb Out" warning
-(4) wire taps to install Load Equalizers
Benefits:
-Instant on, instant off blinking. No more slow "fade" blinking like halogen bulbs
-Crisp 6000K color - Unmatched by any "hyperwhite" incandescent bulb
-Virtually no heat from actual bulb
-No egg yolk - bulbs are perfectly clear when off
-Reduced price as compared to many "Chrome" bulbs (Many of which cost as much at $75!!!)
-Complete kit with instructions and technical support
-Nearly a perfect match for our 6000K HID Kit
-Never burn out!
Installation:
-Bulbs simply plug in. No modification required to the housing
-Load Equalizers tap in with easy junction taps (SEE DIAGRAM)
-Upon purchase, you will be emailed the link and password to our Complete Instruction Guide with color pictures and multiple installation suggestions. We are the ONLY retailers who provide this instruction guide.
Please Note:
-This kit includes Load Equalizers that will heat up to roughly 200 degrees Farenheit. Consequently, the equalizers have 15" wires on each end, to allow you to run them into a FREE AND CLEAR area in the engine bay. Our instruction guide offers 3 possible solutions for mounting them to a METAL, NON-PAINTED surface, away from plastic or flammable components.
(Pictured on an E46... please submit your pictures on an X5!!!)
Thanks all!
JL
